2007 Blue ZX14 with 8,756 miles. ZX10 (08) front fender, Rear Fender eliminator, Dual Yoshimura Slip on's, Braided Front brake lines, PCIII with Ivan's map, PC Ignition module with Ivan's map, Flies removed, BMC Air Filter, Ivan's TRE-006A, Ivan's Block off plates, DB windscreen, ASV Levers, Vortex Rear Sets, Air horns, Aluminum frame sliders, rear hand holds on both sides (from Kawasaki's rear stand kit), Tank Bra, Battery tender, 12V power outlet. I have the factory Kawasaki service manual and the stock mufflers and front fender. Garaged it's entire life, well maintained. $7,500. Located in Hesperia (near Victorville) in Southern California. pssannes@verizon.net (909) 938-1593 open to offers
* Last updated by: BlueNinja14 on 3/18/2012 @ 8:52 PM *
