These are off of my 07(in case it matters) First is a Brocks Street Meg, full system with header. This is the Longer one, where it slants at a 45degree angle. Very clean over all, 2 small dents in the bottom of one of the Header tube about the size of a quarter, Also a little rashed oval slightly bigger than a quarter, on the side of the tube where It drug slightly when I was going through a hard turn. Neither are noticeable unless you are under the bike. $800
Muzzy Nitrous Kit, comes with all the muzzy zx14 wiring harnesses(looks like even maybe an extra harness for some reason), all used by previous owner, but I wired my own setup. I disconnected the horn, and put the horn button in serious with a WOT micro switch, so you had to be at WOT and on the Horn at the same time for it to work. The current pill installed added 50whp to my bike. Also comes with a 10lb purple Zex bottle with pressure gauge, and 2ft hose. So you can just have a shop fill the 10lb bottle, and you can refill the small bottle for the bike yourself. 10lb bottle has about 7-8lbs of nitrous in it IIRC, but if shipping ill probably have to let it all out. Basically, it comes with everything I used on my bike for the last 2 years, plus all the Muzzy harnesses I have that I never used, plus a 10lb bottle. $350
Also have a BMC Race air filter, not much to say about it. Ive had it about 10k miles, cleaned twice, and ill probably clean it before I sell it. $40
Email is probably the best for quick replies, but I tend to be online a lot as well.
kolk1@yahoo.com
