Thread: Soft pannier attachment
Created on: 04/21/16 04:46 AM
banknyank
The Land Down Under
04/21/16 4:46 AM
The good lady & myself are planning a couple of weeks away on the 14 & ive been looking into luggage options. Wanted light weight but with capacity. Decided on the 30 litre per side Ventura bags. They come with Velcro over seat straps, no problem & nylon D rings for attatchment to suitable spots. After stuffing around with the webbing / buckle attachment straps I thought there's got to be a quicker easier answer ? There is, the front D loop on the bags lines up perfectly with the pop out tie down hidden under the 14,s seat, then, to pull the bags rear wards, how cheap & strong are cable ties ? Just cut off & replace each day at the motel. To pull the bags down & back, there going NOWHERE.
GTR 14 with grunt.
* Last updated by: banknyank on 4/21/2016 @ 5:02 AM *
2019 ZX14R in Dark Green
Never let your memories, become bigger than your dreams
RE: Soft pannier attachment
04/21/16 7:27 AM
That's similar to the rig I use. A word of caution though... if you have loaded bags hanging off the rear
bodywork it can crack the rear bodywork mounts. Mine did. I switched to the Twisted Throttle Blaze system which
uses a support bar to take the weight off the panels.
banknyank
The Land Down Under
04/21/16 1:01 PM
Good point Mad, I forgot to add, I've installed a set of these Givi pannier mounts for the soft bags to sit against & hold them off the bodywork. Their light weight & attatch quickly. Frames & bags together around $300 Aus or $200 US, I intend a couple of test rides before committing to the 2 weeks away, but this set up Is very solidly attached, off the bodywork, light weight & relativly slim on the bike compaired to the admittedly better looking but exxy hard bags.
Just another option. They won't be on the bike very often any who.
* Last updated by: banknyank on 4/21/2016 @ 1:10 PM *
04/21/16 1:27 PM
I assume you'll be riding two up. If so, is your lady's booty gonna mind sitting on those straps? Might not be bad, can't really tell ... without an hours-long sit on them.
Looking good.
Danno's Gravatar
Southwestern Illinois
04/22/16 4:48 AM
Get her an Airhawk and she'll never even notice the straps.
Another thing you might consider is some re-usable plastic-coated twist ties. They come in various sizes and colors and survive multiple uses. I was using a zip-tie to tie up the wire on my hitch receiver light and every time I needed to remove it to use the hitch, it was cut-and-replace. Now that I'm using the coated twist tie, one has lasted over a year, and it's more easily removed and replaced than a zip tie.
* Last updated by: Danno on 4/22/2016 @ 4:49 AM *
04/22/16 8:38 AM
My wife sat on the straps for 1500 miles to Oregon and back, said it was no problem at all.
04/22/16 9:58 AM
Good!
Edit: I pasted in the wrong quote!
* Last updated by: extrapolator on 4/22/2016 @ 1:50 PM *
banknyank
The Land Down Under
04/22/16 12:34 PM
Never too old to learn things, 55 by the way, I didn't realise that there are re usable cable ties, release their grip, take off, use again, no wastage, perfect. In black to match the bike.
