You may have seen my pics with my Muzzy stainless dual slips. And you may have read where I bought the OEM centerstand. Well, I tried to get clever (I guess?) and have a bump stop bracket that I fabbed up welded to the right side mid pipe. DAMN MISTAKE. The welder told me welding stainless, "It ain't no problem." That should've been my first clue, but I've had him weld other things, although TRACTOR things, where I barely care what it looks like, and it was all mild steel; no stainless. What he didn't tell me was that he was using MIG and not TIG ... so yep that means the @#$%ing weld will rust. DUMBASS. G@d damn I am pissed. What the F good does it do me to have stainless pipes with welds that will rust??? There is no easy fix for this. The Muzzy pipes are very thin wall (for weight savings of course), so his MIG would burn thru it in less than a heart beat. He "only" burned one hole, but proceeded to fill it with MIG filler, which as I said and I'm sure most of you know will just rust, and immediately. I cannot believe I let this happen. I can't believe I trusted this guy. %#$^!!!!!!!! (fvck)
Since I had plenty of stainless sheet, I got even more clever and fabbed a bracket to be able to bolt the mid pipe at the same OEM mid pipe mid-mount bolt location. I figured with the centerstand hitting the exhaust every time I take the bike off the stand, it couldn't hurt to have the exhaust system secured there, too. Well, he welded that on with MIG also, of course.
So, I have a couple sources for TIG welding, but I don't really think this is gonna be fixable. At the least it's gonna require a piece of lap plate to cover holes, which is gonna look like shit. He did only tack the corners rather than filling the entire lap joint, but still ... I don't think a welder is gonna be able to remove ALL of that MIG to where no rusting metal remains ... AND patch it to where it doesn't look like shit. This sucks so bad.
I still hold out some minute amount of hope that one of you will have a good idea for a fix.
But, pretty sure I'm gonna need to know: Anybody have any idea where I can just get a replacement stainless right side mid pipe? I'll try Muzzy later today, but last time I talked to them they said they make these in batches only every so often, so it will be a long wait. Maybe I just have to wait that wait. DAMMIT. I spent a helluva a long time on those brackets too. DAMMIT!
