Darn it! Went across 2x4 on the highway, lucky to report only both mid pipes dented...at 70mph...if anybody have a set maybe even with cans that wants to get rid of them - let me know at xpecaros@yahoo.com or PM....South Florida
Created on: 04/08/13 06:11 PM
s4rhoolie
RE: WTB mid pipes for 06-07 ZX14
04/09/13 10:42 AM
You'll probably need the headers too if they also took a bend you can't see? Unless the others fit no problem.
I have a set of '06-Is the left pipe is gutted and shortened a smidg. It has a bearing to lower the sound = Muffler bearing? That's how the coin came from. Quiethenginexhausthe fuk if I know?
I have a set of '08-Is the header has a bung and the pipes are stock. Neither set is pristine as if they were take-offs: someone put on a 4-in-1 meaning. However, there are no dents in either set. Scratches you have to walk up to with the '08 set. There are the usual oil stains by the chain lube fling in other words.
On the '06 muffler it's possible the beauty ring is off the right side, I forget? They are wrapped up. But for sure the left muffler has the ring off near your foot area. I have no clue what either set is worth? Make an offer we can agree upon. That means the shipping might be about $90 alone with that kind of weight and distance. So you have to add that too to your decision.
There is a packing between the header and muffler that is different. BTW, Rook is correct. The mid is welded to the muffler. The exhaust is a 3 piece item with the only difference is, you swap an 06 packing for an 08 muffler packing, the header year calls the packing. Any year muffler works on any header [if] you match the right packing to the header, meaning the packing O/D is the same. The packing's I/D is different. '06 was smaller without cat, '08 became larger with cat installed in the header.
