I took it out and put it back in in winter. Now wanted to remove it again because I decided that little 106" lb torque on the detent arm and shift cam really should have a backup of thread locking agent as specced in the SM.
I got the parts I wanted out but darned if that shift shaft would come out. It just about comes all the way out and then it hits against something on the other side of that clutch case wall. Don't know what it could be. The shift shaft tapers down before the serrations so I believe it has something to do with that----allowing another part to drop down in the tunnel and catch on the edge of the serrations.
The shaft was perfectly straight when I put it in. I checked. No excessive wear, just some marks where it contacts something in there but no actual reduction of the diameter. It did take some cajoling to get it out and in the first time but now???? I didn't want to force it.
There is a set of roller bearings on either end of the shaft, isn't there? Maybe the inner set is what's dropping down on the edge of the serrated part. I did not lube the thing before reinstalling it. Figured there must be oil in the tunnel since the shaft was dripping when I took it out. Now it is dry like when I put it in.
Maybe some oil would help the shaft slide out?
Thoughts?
