Sale Pending
Sad to say but I sold my ZX14 and have a few parts to sell left over , First on the list is the Green Valve Stems. Never wore out the second set of tire so these are new in the bag, never used, untouched .
I picked them up at Kurveygirl.com where they are $29.00 plus shipping.
Im asking $25 including shipping, payment PayPal or cleared Check /MO
Ill let them sit on these sites for a bit then its off to flea bay for the feeding.
Please PM me or Email at youdontneedit at hotmail dot com (yes thats my real email)
I quote the internet page
“Fitting general rule of thumb: 11.3mm fits most every Japanese manufactured tubeless tire rim since the early 80's.
Additional fitting information: Valve stems needs a flat region of 17.6mm (0.7in) around the valve stem.
• To check the clearance, use a socket that is about 18mm in outer diameter.
• Place socket around the current valve stem with the valve stem sticking though the center of the socket.
• If you have a flat region that fits a socket of about 18mm, then you should have enough clearance. “
“Assembly Instructions:
1. Remove old valve stem
2. Clean both valve body and valve stem hole on rim.
3. Insert valve onto rim, taking care not to damage the gasket at the base of the valve stem.
4. Attach the nut on the inside of the rim to the valve stem threaded body.
5. Set valve stem torque to 7Nm to 10Nm. (5.1~7.3 ft-lb / 62~88 in-lb)
Note: Excessive torque may damage the all aluminum valve stem threads.”
https://blu2.storage.live.com/items/74ABCF6268B22B6C!278:Scaled1024/IMG_0321.JPG?psid=1&ck=0&ex=720
* Last updated by: imrubicon on 4/14/2012 @ 6:48 AM *
2012Yamaha Tenere 1200 for really wandering off the beaten path
2005 GL1800 Sold to another to enjoy
2006 ST1300 Gone but not forgotten
2009 ZX14 Also gone and will be replaced someday
some of the best of both worlds
