Everything is for sale!!! I haven't pulled a thing, but I'll be working on it this week. Shipping will be slow as it's the holiday season.
Please email me instead of pm.
I am the original owner of the bike. A little over 12k miles on the bike itself, but all the turbo, suspension, arm, and pcv have about 50 miles on them (brand new condition)
I'll be looking for a stock clutch cover as well as a stock oil pan.
As you can see from the pictures, the body was modified to fit a turbo kit, that being said, it's in great condition. The only flaw worth mentioning is on the gas tank. The front part that goes under the cowel had paint spilled on it, so it's a pinkish color and bubbled. This bike has never been down.
$900 plus shipping for all body work and gas tank, minus fuel pump and front fender
I will probably ask $2000 plus shipping for the motor with stock head gasket, oil pan, cam gears, and clutch (the clutch pack is brand new). I'll include the muzzy smog plates, and carpenter valve springs on this, but I'll probably pull the throttle bodies and wiring harness unless you want to pay a bit more. I can include more parts, or take some off..... willing to work with buyer for this one.
$2000 plus shipping
Clean and clear frame with title
VIN: JKBZXNA1X6A010485
$1250 plus shipping
Subframe
$125 shipped
Cycle Logic Turbo kit with upgraded 20g turbo (450hp capable) and external 38mm TiAL wastegate. Lots of custom stuff done to this as well, such as a blow off valve, tig welded dump pipe, AEM dryflow air filter, frame plugs, oil cooler block off, external oil pump and lines, oil lines, etc... This is EVERYTHING you need to turbo your bike minus fuel system and engine management. I will include the oil cooler block off cause you'll need it (the turbo is too big for the stock oil cooler).
$3000 plus shipping
Cometic 0.070" head gasket (lowers compression to about 10.29:1)
$50 shipped
APE adjustable cam sprockets
$40 shipped (this might be a week or two before it's available to ship)
Adams boxed oil pan (has some damage from scraping on bottom but works great)
$130 shipped
Gann multi-stage lock up clutch with modified clutch cover
$300 shipped
Walbro 255 lph in tank fuel pump (in an 06/07 housing)
$75 shipped
Bosch EV1 700cc injectors
$250 shipped (these will take a little while to remove as well)
Power commander V
$180 shipped
Dynojet Auto Tuner
$175 shipped
3 bar gm map sensor
$40 shipped
MPS Air shifter (this includes the kill box, various lines, fittings and bolt to hook up to a zx14, and a pump. Only thing you'll need is an air tank of some sort)
$175 shipped
Evil Swingarms chromoly 7-11" over with built in air tank (powdercoated black), and chainguard (for zx14)
$500 shipped
Trac Dynamics revalved shock and 11.0 kg spring
$170 shipped
Front forks (I tried stripping off the powdercoating but I couldn't get all of it. They work perfectly)
$165 shipped
Buell footpegs (modified to fit zx14, aka these are bolt-on unlike other buell pegs)
$18 shipped
Brocks lowering brackets and strap
$40 shipped
Soupy's adjustable lowering links
$60 shipped
EK DRZ-2 chain (very low mileage. I'm not sure on the length, but at 16/41 I was 11" over and still have another 10+" of chain left)
$80 shipped
Vortex 16 tooth front sprocket (great condition)
$10 shipped
zx14 wheels in silver (great condition), rear wheel is a brand new 008 shinko slick, and the front is a 120/60-17 dunlop with good tread
$250 shipped
zx10r front fender and brackets to mount it (this is a red fender, and I made the brackets)
$100 shipped
Front brake rotors
$45 shipped each
Front brake calipers
$45 shipped each
Rear brake rotor
$25 shipped
Rear brake caliper
$25 shipped
headlights
$190 shipped
tail light and rear blinkers
$50 shipped
Fuel pressure gauge, billet mount, and lines
$50 shipped
Boost pressure gauge, billet mound and line
$40 shipped
Stock seat
$65 shipped
Clip ons with levers, reservoirs, grips, throttle, buttons, etc
$150 shipped
Radiator and fan
$125 shipped
Tiger tail undertail
$85 shipped
Rear brake line (stainless steel made for at least 12" over)
$15 shipped
Throttle bodies (no injectors, but will include fuel rail)
$75 shipped
Frame sliders
$15 shipped
Gauge cluster
$150 shipped
Ignition, key lock, gas cap set (with 2 keys) and triple clamp
$80 shipped
FIRST PERSON TO PAY GETS IT!!!!! MAKE SURE YOU INDICATE WHAT IT IS YOU'RE BUYING!!!!!
PAYPAL IS GILBERJJ@GMAIL.COM
If you don't see what you need, but think I may have it, shoot me an offer.
PLEASE EMAIL ME AT GILBERJJ@GMAIL.COM. This will be on several sites and it's very difficult to manage through PM's.
Thanks,
Jorgen
(360) 481-8998
