I keep reading in road test reports that the LCD display on the ZX-14R can be changed from a dark backround and light lettering to light background and dark letting, but I must have missed the "how to" in the user manual. How do you do it?
Jim G
Created on: 01/26/19 08:00 PM
JimGnitecki
Changing background colour on LCD instrument panel?
01/26/19 8:00 PM
Jim G
JimGnitecki
JimGnitecki
RE: Changing background colour on LCD instrument panel?
02/05/19 2:15 PM
Key on--Hold (L) top button and wait for change.
To return = Repeat the hold down top left button.
I tried this Hub but must have f'd up as usual, which L top button again? I tried the upper toggle/button of the multi-function switch, the Select button and nothing happened ... Just read thru the User manual and the SM and did not find anything on this hack.
JimGnitecki
02/05/19 4:41 PM
The user manual instructions, at least in the manual for the Gen 2 bikes (page 65),is not very clear. Try this:
1. You need to have one of the "upper" display items selected at the time (e.g. Outside temp, Battery voltage, Range, etc). i.e. press the upper button briefly to ensure that is where you are at the moment.
2. Then press and HOLD the upper button for at least 2 full seconds
Watch the display while doing so. The display should then "reverse" to the other setting.
Let go of the button when it does.
Jim G
* Last updated by: JimGnitecki on 2/5/2019 @ 4:42 PM *
moppedmanniemie
21744
