Thread: High beams not on unless switch is hit
Created on: 03/02/15 11:47 AM
Nitti
Nitti's Gravatar
03/02/15 11:47 AM
Need help. When my bike is running the regular headlights and city lights are on but the high beams lights are not on at all. However, When i hit the high beam switch the high beams do come on. Prior to this problem and got my ECU Cblasted and I switch out the factory battery for shorai and I changed my city lights from factory clear to blue. Any suggestions/solutions to this problem would be appreciated. Thx
Philly Xtreme M.C.
"Assault the Asphalt Because Fear is not an Option"
RE: High beams not on unless switch is hit
03/02/15 12:40 PM
I don't understand the problem. Please re-state.
Edit: Oh I understand now ... but sorry do not have an ideas.
* Last updated by: extrapolator on 3/2/2015 @ 12:41 PM *
Nastynotch
Nastynotch's Gravatar
03/02/15 12:42 PM
+1
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
Nitti
Nitti's Gravatar
03/02/15 12:45 PM
When a 14r bike is running all the headlights are suppose to be on. High beams or low beams until you turn on the high beams. My high beams have no low beam. High beams come on if the high beam switch is on. If the high beam switch is off the lights are out completely.
Philly Xtreme M.C.
Nitti
Nitti's Gravatar
03/02/15 12:55 PM
http://www.google.com/imgres?imgurl=http://1100rr.com/Picture%2525201447.jpg&imgrefurl=http://www.bikeland.org/board/viewthread.php?FID%3D27%26TID%3D65944&h=480&w=640&tbnid=KWIHrFtVFD9gpM:&zoom=1&docid=nMTqAD6LatYjmM&ei=gL70VOGmOcHksASNkIEY&tbm=isch&client=tablet-android-hms-tmobile-us&ved=0CIYBEDMoXjBe
this is how my lights suppose to look when the bike is running but this is how it looks when its running
http://www.google.com/imgres?imgurl=http://i325.photobucket.com/albums/k393/ssl509/lightsamber.jpg&imgrefurl=http://www.bikeland.org/board/viewthread.php?TID%3D48102%26FID%3D27&h=768&w=1024&tbnid=2OvKQ1EB1wSVrM:&zoom=1&docid=9CjcArDI2rtDWM&ei=4b_0VIKnHO3isATbx4GYDg&tbm=isch&client=tablet-android-hms-tmobile-us&ved=0CCsQMygjMCM4ZA
Philly Xtreme M.C.
03/02/15 12:59 PM
"When a 14r bike is running all the headlights are suppose to be on"...no,they're not.High beams are just that.Switch activated.Low beams?They SHOULD be coming on at startup.(automatically)
Your lamps are fine.That top pic...that's correct.That lower pic...high beams switched on.Your bike's fine.
Someone tell you yours was not okay?It is.
I'm assuming you have that White ninja there.You do know there's a HIGH BEAM passing switch on the left handlebar switch housing.Operated with the index finger.You can be in LOW BEAM mode,and for passing,simply pull that little finger switch there(in front of the housing).It will allow high beam flashing.High beam mode,the switch doesn't do anything.Nice little safety feature I think.
* Last updated by: Grn14 on 3/2/2015 @ 1:07 PM *
Nastynotch
03/02/15 1:22 PM
Is there a separate fuse for the low beams?
2013 ZX-14R SE
V1 custom mounted
Nitti
Nitti's Gravatar
03/02/15 1:49 PM
Yes GRN I have the white ninja. Thx for the input. No1 told me it was wrong. I assumed it was wrong cuz im use to seeing the top pic when my bike is running. The other day i started it after a few small mods i saw the bottom pic and got worried something was wrong. Didnt know about the switch for passing in low beam mode. I will definitely be checking that out.
Philly Xtreme M.C.
03/02/15 3:17 PM
