Thread: My Turbo Build
Created on: 09/14/14 07:35 PM
Fazer
Fazer's Gravatar
My Turbo Build
09/14/14 7:35 PM
So I though I would document my turbo build here...
Little bit of back ground.
Brand new '10 roller frame and plastics with a used (rebuilt) 08 engine.
Bike didnt run all that well so i decided to reflash the bike. Turns out I had an 06 ecu with 08+ injectors... With some assistance from romans my 06 ecu was reflashed to an 08.
Shortly after that i decided to slap romans turbo on my bike...
The bike ran amazing right up until the day i did a leakdown test. Cylinders 1,2,4 were at about 20% loss and #3 was close to 60%
Yet it still ran great (lol)
Strip down began...
2014 ZX-14R Turbo
Fazer
Fazer's Gravatar
RE: My Turbo Build
09/14/14 7:48 PM
Head off... What do we find? #3 wall bought the farm
Cooked piston is on the menu tonight... And a huge WTF... Piston in backwards... Rings welded to piston at incorrect angle *sigh*
Bearing look brand new... Rods not so much...
Clutch was "well done" as well... New plates ordered!
Thanks to the service manual things were going very smooth ....up until i came across the screws that hold on the transmission blocking plate thingy... Screws are made of fine soft french cheese.... No match for my drill though!!
* Last updated by: Fazer on 9/14/2014 @ 8:01 PM *
2014 ZX-14R Turbo
Fazer
Fazer's Gravatar
RE: My Turbo Build
09/14/14 7:59 PM
Case is off for replating so it was time to order some new parts!
New low compression turbo pistons and new wossner rods
New Carpenter valve springs
Might as well remove the flies while im in there...
And some 06-07 injectors too... 08's out
* Last updated by: Fazer on 9/14/2014 @ 8:30 PM *
2014 ZX-14R Turbo
Fazer
Fazer's Gravatar
RE: My Turbo Build
09/14/14 8:15 PM
Im about 1-2 weeks away from being complete so i am really excited to get her back out on the road!
The parts list to date...
- Used Engine Case, replated
- Wossner Rods
- Wossner Pistons
- Carpenter Valve Springs
- MTC Lock-Up Clutch
- 06-07 Injectors
- Muzzy Oil Plate
- OEM crankshaft bearings, OEM rod bearings, misc nuts and bolts
- OEM clutch pack
- OEM Head Gasket
- Brocks Clutch Springs
- misc tools
- Engine Heading cleaning
- New 44T rear sprocket
- 12 lbs boost spring
Biggest expense was for bearings, nuts and bolts, and misc tools.... Probably 1/2 the cost of the project.
2014 ZX-14R Turbo
RE: My Turbo Build
09/14/14 9:35 PM
The Ricardo det problem.
2006 = richer than 2008 injectors.
So if you had puddling and she goes boom with the 2008's imagine the puddle with the '06.
RE: My Turbo Build
09/14/14 9:37 PM
And look at that det off the cylinder wall. At peak TDC that bang happens there and look at where it began to peel. So say peak peel as it eats more off the wall.
grin14
Northamptonshire uk
RE: My Turbo Build
09/16/14 6:40 PM
I had exactly the same problem when the frost plug blew out and dropped the fuel pressure by 4psi, heard it det even with my helmet on, got out of the throttle immediately but that wasnt fast enough when giving it some! det damage was about the same 6 areas where i could see the rings(on three pistons and det damage to 0.199mm into the cylinder wall.
Decided on second hand cases.....etc etc.......
Did you hear it det?
RE: My Turbo Build
09/20/14 1:18 PM
At least u had to stones to tackle it yourself. Good work. Now get it on the road!
Fazer
Fazer's Gravatar
RE: My Turbo Build
09/21/14 6:00 PM
Well the engine is complete. 20 hours later lol
All went smooth except for the shift shaft install and the camshaft install ( which were a total fucking bitch to do)
Hopefully i will have the engine back in tomorrow.
2014 ZX-14R Turbo
wfozx14
wfozx14's Gravatar
Upstate New York
RE: My Turbo Build
09/21/14 6:23 PM
Don't get to excited and forget to put the oil in.lol. Sounds stupid I know, but I've seen it happen.
Fazer
Fazer's Gravatar
RE: My Turbo Build
09/21/14 6:28 PM
haha! Ill make sure i cross all my t's and dot all my i's
* Last updated by: Fazer on 9/21/2014 @ 6:29 PM *
2014 ZX-14R Turbo
zx14beast
zx14beast's Gravatar
RE: My Turbo Build
09/23/14 10:42 AM
You better have this thing running by tonight!
The Gap train waits for no man.....even if he drives a turbo bike.
* Last updated by: zx14beast on 9/23/2014 @ 10:43 AM *
WillsZX14R
WillsZX14R's Gravatar
RE: My Turbo Build
03/17/17 6:27 AM
Ancient thread but hope this build was completed? enough years have passed. Post recent photos?
RE: My Turbo Build
03/28/17 4:09 PM
Love to see dem pics.
Fazer
Fazer's Gravatar
RE: My Turbo Build
01/06/20 10:34 AM
Ending up selling the bike shortly after completing the build. Ran great but the fuel pump blew up. I was tired of working on the bike so I sold it to Romans. Not sure where it ended up. Curious to know what happened with it.
Just finished installing my RCC turbo kit this weekend for my 2014 14R. Awesome kit and a relatively easy install!
2014 ZX-14R Turbo
RE: My Turbo Build
01/06/20 2:54 PM
Have you done any internals prior to installing turbo ?
Fazer
Fazer's Gravatar
RE: My Turbo Build
01/06/20 7:46 PM
Only doing billet oil pump cover and stiffer clutch springs. Planning on staying at 4 lbs boost.
* Last updated by: Fazer on 1/6/2020 @ 7:50 PM *
2014 ZX-14R Turbo
Zxpredator
Zxpredator's Gravatar
RE: My Turbo Build
01/07/20 2:46 PM
this turbo is well hidden. i want to do this.
do you have more pictures?
RE: My Turbo Build
01/07/20 5:15 PM
Will you be doing a dyno run when finished..? I would like to see it m if so..
Fazer
Fazer's Gravatar
RE: My Turbo Build
01/07/20 5:45 PM
I plan on doing a dyno session at RCC sometime in the spring just to confirm everything is operating properly. Should be putting out about 250 at the wheel.
Still have to install my gauges, install oil pump cover, and do clutch springs. Should be done this weekend. Ill post up more pictures soon.
Only 4 more months until I get to ride it lol
2014 ZX-14R Turbo
RE: My Turbo Build
01/08/20 6:41 AM
On the clutch springs, don't worry about the lever being too stiff. I have HD clutch springs and it's only a little tighter in the lever.
Fazer
Fazer's Gravatar
RE: My Turbo Build
01/08/20 10:10 AM
Ya i had them on my Gen1 and I dont recall it being bad. Having said that I am commuting alot farther now so hopefully it doesnt suck.
2014 ZX-14R Turbo
