Thread: Good News I think ?
Created on: 10/07/17 10:01 AM
suzy1052
suzy1052's Gravatar
Good News I think ?
10/07/17 10:01 AM
The Hindle Evolution from my 06 fits my 2016 with good clearance all around after Hindle cust service said it wouldn't. Now for a little bad news. The 02 bung is not only on the other side of the new pipe its also too small to screw in. Iv'e been reading that the 16 and up ecu's are different and hard to turn off dash lights. Is there a 02 eliminator that will work on the 16 and should I start it before I have the 02 situation fixed ?
RE: Good News I think ?
10/07/17 10:34 AM
he's your man
suzy1052
suzy1052's Gravatar
10/07/17 11:07 AM
Thanks ole buddy ! I'm gonna pm him now.
10/07/17 1:52 PM
I was going to suggest having a weld shop put the right size bung in the right place and then just plug the old bung.
10/07/17 8:13 PM
If you do, bring the whole bike in so they see how much clearance the O2 sensor requires.
10/08/17 9:58 AM
Here's the solution:
Yes you can ride around with the 02 disabled with our without a pig helper.
Yes you can install a PC and add the autotune with the 02 unplugged and find the PC's 02 'position*.'
Yes you can run a 13/12+ AFR number of your choice and let autotune clean up the numbers, save and run that map.
OR:
Yes you just buy a bung from a muffler shop/on line, weld/braze the bung at an angle to clear the frame so the position has a slight 'drain angle*'... so as to keep the condensation from settling [horizontal] and rusting out the 02.
Yes you can run without a PC with the 02 back in the loop with the bung in the Hindle somewhere.
Yes you can pick a header tube if the collector has no room for the bung's angle.
No you cannot plug the 02 in and let it dangle in the air; it will just code as if unplugged.
* = means the same thing as far as condensation integrity.
suzy1052
suzy1052's Gravatar
10/08/17 1:00 PM
OK thanks Hub I think I'll just get it shut off.
