Thread: Throttle Body Sync (tools)
Created on: 12/20/09 10:51 AM
TerribleTed
TerribleTed's Gravatar
roseville, sacramento, ca
12/20/09 10:51 AM
So I wanna sycn my 20006 zx14 Throttle Bodies..
which throttle body sync tools did you use for this...
As in manufacturer..model number..etc
any links would be great,..,
I wish to know this data from users that have actually done this adjustment...not those hat have not..
* Last updated by: TerribleTed on 12/20/2009 @ 10:52 AM *
Terrible Ted
RE: Throttle Body Sync (tools)
12/20/09 11:04 AM
12/20/09 12:04 PM
I just used a vacuum gauge tester from Harbor freight. U.S. General ITEM 93547. It was about $12. It probably is not accurate as a liquid vacuum tube tester because the needle on the vacuum gauge shakes a lot with the engine at idle. I checked mine with engine speeded up to ~ 3000 rpm and that made the needle pretty steady. Both banks looked the same so I considered it synced. Next time, I would try to get my hands on an inexpensive vacuum tube tester though.
12/24/09 8:32 PM
"Pilot Screw Adjuster" ~ 57001-1292
"Vacuum Gauge" ~ 57001-1369
See your dealer for prices.
Let me save you a phone call. The vacuum gauge is about a grand.....
or was that the kawi special tool tachometer that you are supposed to use? Either one is cost prohibative. I checked with the dealership and some website and there is no way anyone will pay those prices for an occassional sync. I doubt if most shops even have the exact items recommended.
* Last updated by: Rook on 12/24/2009 @ 10:38 PM *
darryle
darryle's Gravatar
12/29/09 2:41 PM
If you use inexpensive vacuum guages go to a pet store and buy aquarium pump needle valves this way you can stableize the needle fluctuation.I did that on my ZRX and then rechecked with motion pro mercury stick,worked fine
