Thread: Rook's tutorials
Created on: 02/24/12 12:00 AM
Rook's tutorials
02/24/12 6:38 PM
AFTER GETTING ALL OF MY PHOTOS ORGANIZED AND RELOADED TO THE TUTORIALS, PHOTOBUCKET DECIDED THEY WOUOLD NO LONGER PROVIDE HOSTING TO OTHER SITES FOR FREE AND THAT IS WHY MANY TUTORIALS HAVE NO PHOTOS. I AM IN THE PROCESS OF LOADING THE PICS TO THIS SITE SO IF YOU NEED TO USE ATUTORIAL, LET ME KNOW AND I WILL UPDATE IT WITH THE PICS ASAP.
These are all for Gen1 bikes, 2006-2011. Not all will apply to ZX-14s after 2011.
APPEARANCE MODS
Coolant Reservoir Blackout
PlastiDipping Water Hoses
How I Painted My Rotors
Painting--Rear Sprocket
BODY AND EXTERIOR PARTS
FAIRING REMOVAL, GEN1
Rear fender removal and DIY fender eliminator
How To Stop Seat Cowl Rattle
BRAKES
Brake Disk Removal, Front and Rear
Rear and Front Brake Pad Install
COOLING SYSTEM
cooling Sysytem flush/coolant change
Engine Coolant Reserve Tank Removal
Water Hose Removal, Gen1
DFI
How To Remove Air Box Access Covers
AIR CLEANER DRAIN HOSE REMOVAL
HOW TO REMOVE AIR FILTER ELEMENT
Fuel Hose Removal
How to Remove Fuel Tank
unstick your fuel tank cap lock
Fuel Tank Cover Removal
INTAKE DUCTS REMOVAL
Throttle Body Assembly Removal
Throttle Body Bores and Butterfly Valve Cleaning
THROTTLE BODIES SYNC, GEN1
Throttle Bodies Sync Tools use
Throttle Cable Removal
Throttle Cable Clean and Lube
ELECTRICAL SYSTEM
Battery terminal cleaning*
Battery Removal and Shorai 14Ah Installation
CAMSHAFT POSITION SENSOR REMOVAL
Crankshaft Sensor Removal, Ge1
Engine Subharness Removal
Horn Removal [beep-beep]
Intake Air Teperature Sensor Removal
Gen1, How to set the Multifuction Meter
AFTERMARKET OIL GAUGES INSTALL
Oil Pressure Switch Removal
Rear Brake Light Sensor--Aftermarket Pressure sensor
Regulator/Rectifier Removal, Gen1
SPARK PLUGS REMOVAL: BY SPYGLASS
SPEED SENSOR REMOVAL
SpeedoHealer SHv4 with RTSR underseat install
STICK COIL SUBHARNESS
How To Clean Stick Coil Wells
Stick Coil Removal
Tail Light Removal
THROTTLE BODIES SUBHARNESS REMOVAL
-----Dynojet Products
Download and Use Apache OpenOffice to View Log Files
Auto Tune-200 Underseat Install
AFR Tuning Basics With AutoTune
DISPLAY FILE MANAGER 1.0.4
Dynojet Downloads and Install
LCD-200 Installation
LCD-200 Setup and Functions
PC5 under seat installation
HOW TO LOAD MAPS AND AN OVERVIEW OF POWER COMMANDER 5 V 1.0.6.4
ENGINE
APE Manual CCT Install
Cam Chain Tensioner Removal
Camshaft Removal and Installation
Camshaft Tests: Runout, Cam Wear and Cap Wear
Crankcase Vent Pipe Removal
CRANKSHAFT POSITIONING
compression test
Oil Sensor Sending Unit Adapter Mod
ENGINE OIL AND FILTER CHANGE
oil pump removal, aftermarket oil pump cover installation
VALVE CLEARANCE AND ADJUSTMENT
-----Engine Covers
CLUTCH COVER REMOVAL
Crankshaft Sensor Cover
Cylinder Head Cover
Cylinder Head Cover Gasket Leak Washer Fix
SPROCKET COVER REMOVAL
-------Engine Equipment
Heat Insulator Rubber Shield, Engine
Heat Shield Wings Removal
EXHAUST
Remove PAIR, Install blockoff plates
PAIR block off to reduce backfire/popping
FRAME
Left Side Subframe Removal
-------Frame Equipment
TOOLBOX REMOVAL
FUEL TANK AND MUDFLAP BRACE REMOVAL, GEN1
Terminator Plug/Wire Harness Bracket, LH side frame
HYDRAULIC SYSTEM
BRAKE CALIPER REMOVAL-FRONT AND REAR
Brake and Clutch Fluid Bleed and Purge
BRAKE LINE REMOVAL- After Market Install
Clutch Line Removal
CLUTCH SLAVE CYLINDER REMOVAL
STEERING
Fork Clamp Torque
SUSPENSION
Front and Rear Suspension Removal/Ohlins install, Gen1
SUSPENSION TUNING, solo method
TOOLS
HOW TO USE A HEINDL SWING ARM PIVOT STAND
HOW TO MAKE A PLATFORM FOR THE PIT BULL TRAILER RESTRAINT AND U-HAUL MOTORCYCLE TRAILER
How to use the PIT BULL Newfrontstand
How to Use the Sync-Pro Manometer v Vacuum Gauges
How To Check Torque Wrench Calibration
HOW TO USE THE ABN VACUUM GAUGES V THE SYNC-PRO
TRANSMISSION
External Shift Mechanism Removal and Inspection
CLUTCH HUB AND BASKET REMOVAL
Clutch Springs, Spring Plate and Clutch Pack Inspection
Gen1 Clutch Springs, Spring Plate and Clutch Pack Removal
DRIVE CHAIN SLACK ADJUSTMENT
Gilles Tooling kts Chain Adjusters Install and Safety Mod
Sprockets and Drive Chain Replacement
WHEELS
TIRE AIR VALVE REPLACEMENT
TIRE REMOVAL AND MOUNT
How To Remove and Install Front and Rear Wheels
Wheel, Axle, Rotor and Sprocket Inspection
WHEEL BALANCING
WEIGHT LOSS
How to Loose 100 lbs From Your Gen1 ZX-14
How to Test Steering Play
Tail Subframe Removal, Gen1
LED Tag Light
TechSpec Installation
Vortex Rearsets Install
How To Apply Wheel Tape
Head Cover Gasket Leak Fix
Hot Wind Cover Pads and Brackets
Control Levers Removal and Lube
Side Stand Removal and Lube
HM PLUS Underseat Install and Setup
Seat Lock Cover Removal
Dzus Fastener Install
LSL Frame Sliders Install
Ohlins KA-544 Shock Adjuster Relocator Brackets
* Last updated by: Rook on 8/3/2020 @ 11:38 AM *
RE: Rook's tutorials
02/24/12 6:41 PM
I was listing these at the top of the fairings tutorial but that was making the post too long and some of the end of that tutorial was getting chopped every time I added another link at the top. So here it is. There is a link at the top of fairings tutorial that comes here so this can go to the bottom of the How Tos but ut will still be easy to locate if anyone needs something. I'l just keep adding links here as I write new tutorials.
* Last updated by: Rook on 2/24/2012 @ 6:42 PM *
COOTER
COOTER's Gravatar
South West Florida
02/24/12 7:07 PM
Make this a sticky thanks again Rook and keep them coming!!!!
02/25/12 2:26 PM
Thanks BG.
bgordon
Forum Administrator
bgordon's Gravatar
Grand Junction, CO
02/26/12 4:36 PM
Thank YOU! -bg
02/27/12 5:07 PM
KoflaOlivieri
KoflaOlivieri's Gravatar
Philadelphia, PA
04/12/12 8:44 PM
These are excellent tutorials, thank you!
* Last updated by: KoflaOlivieri on 12/13/2018 @ 10:54 PM *
04/26/12 9:23 PM
Taffs201014
05/09/12 1:08 PM
I hope our stealers dont read this site or a contract will be out on the genius known as rook. Rook, in my 36 years of big K I have never found anything as useful as your 'how to's' and tutorials. Long may they continue.
I wonder if folk here realise what ROOK stands for? Really Outstanding On Kawasaki. Never a truer word ay mates.
05/09/12 4:20 PM
It was all inside Rook. He was a diamond in the rough way back when, Taffs. You should have been around to see him blossom. And now look.
05/09/12 6:39 PM
Thanks, Taffs!! hahah!! That's awesome!!
Still a long looooooong road ahead of me, Hubster. Thank you for the tremendous amount of patients and help so far.
There is a little bit of Hubdom in almost every one of these. The Valve Clearance tutorial was something I couldn't have ever finished without Hub's tutelage.
Taffs201014
05/10/12 4:53 AM
Rook, For HUB is this too good or shall we use it? HUB is:- He's Utterly Brilliant. Keep up the great work amigo's you have saved me from the stealers this past year or so. I dont see me swapping my 14 for the new one for a long time if ever so your tutorials are bbbbbbbrilliant.
05/11/12 11:39 PM
perfect!
pinbot1966
05/28/12 4:34 PM
Thanks for your tutorials Rook, well done and they definitely have saved me anger and frustration.
05/30/12 7:51 AM
thank you for the feedback. I'm glad it/they helped you!
gfunko
gfunko's Gravatar
08/01/12 5:31 AM
ROOK, you are a gentleman and a scholar! Thank you!
JonandTay
JonandTay's Gravatar
08/13/12 7:32 PM
Thanks for the battery removal guide Rook - it really helped me out today.
10/17/12 8:03 PM
Thanks for posting here, folks. Always nice to know someone is using this stuff.
10/17/12 8:47 PM
Well hell yeah someone's using it!F'n A bro...you're the site 'go to' guy for this stuff!These write ups are perfect....
10/17/12 9:35 PM
heh HEEEE!! thanks buddy. More to come this winter.....
We need a 14r tutorial guy around here now.
01/06/13 6:41 PM
Great Job Rook. Amazing Really
yannih
yannih's Gravatar
Queenstown New Zealand
01/14/13 4:00 PM
Rook, your tutorials are rubbish and are not detailed enough...
Nah, just kidding.
Just wanted to be different, change it up a bit from all the glowing feedback here and keep your head to a size to fit into your helmet!
They're brilliant and have helped me heaps.
Thanks again for all your great work...
* Last updated by: yannih on 1/15/2013 @ 3:11 AM *
01/15/13 8:03 AM
Thanks Yannih!
HoltFF1074
HoltFF1074's Gravatar
08/06/14 8:11 PM
wow rook,fantastic stuff! As a newbie 14 owner (010 SE) and these guides will help soooooooooooo much. I've been locked in on various how-to's for the last few days. Hard to pull myself away. Can't thank you enough for all you've shared and documented. After reading about pulling the wheels is helpful as I'm needing to have new rubber mounted on the front. Great forumn and a wealth of knowledge being shared. Hard to beat that!
You only live once....if that Long
08/06/14 8:46 PM
Glad they help. LOL they help me too! I come back and read them for most jobs I do a second or third time.
