the roll is my left hand; I spin the adapter clockwise. Visualize snapping the tape after 3 wraps worth, and curl the strands around the threads in the same direction. See how if you spun the male into the female the tape break would be flat, not being bunched up if taped the other way?
You're describing how to wrap the tape so it compresses harmoniously between the male and female threads so it does not bunch up. Yup. I've always done that.
there's a pipe thread board that if you take the pipe thread, find the one that matches the pitch, this will tell you. Looking up an oil switch for a car might use the same size and might say what pitch and diameter or start pulling parts unit something fits and then read the box you got the part from.
You can buy a thread gauge which is like a bunch of saw tooth blades. The problem is that you might need to buy a few sets before you find the right blade.
There are more than just the standard american pipe threads like 1/8" NPT National Pipe Thread or FNPT for female.
Yes, there is AN which is parallel threads and BS-something
But there is also metric pipe thread sizes which you won't find at your local hardware store and there is a British standard and British parallel port which uses an o-ring seal. I doubt its the British but it could be metric which is very close in size but I think slightly smaller.
--and there's those.
Hopefully the sensors on our bikes us a standard taper pipe thread.
I have a feeling they are. I bet it is 1/8 NPT. I read about a guy doing gauges back in 2008 and there is a vague recollection of some details.
I order my hoses custom made from this place online, they may be of help.
Thanks, piken. I may have to go with that if I can't figure it out.
Come to think of it, I might have figured this out now after reading your comments. I have the sensors for the gauges right here along with install directions. The directions must say what type of fitting the sensors should be used with. If the gauge sensors have the same threads as the OEM sensor, I've got it! If not, I have a mystery to solve.
* Last updated by: Rook on 3/13/2017 @ 4:20 PM *
