Thread: zx14 stalls out
Created on: 03/25/14 05:25 AM
sooner
zx14 stalls out
03/25/14 5:25 AM
Hey do anybody have a ideal on what to look for when your bike stalls.What i have is the bike runs great in neutral when i give it gas it accelerate great but when i put it in first gear and start to accelerate the gas it stalls and cuts off.I have checked all the lines that i can see.Can someone help before i have to take to shop.
RE: zx14 stalls out
03/25/14 7:49 AM
Just a guess, Do you have a PowerCommander or similar device? Could be that the map is off?
Another guess, how long since you changed spark plugs? I have over 40K on my plugs and it runs fine but the plugs are way overdue.
sooner
RE: zx14 stalls out
03/25/14 7:55 AM
Rook bike is a wrecked bike that i am rebuilding the paper work shows mileage to be under 500 miles but i will checked the plugs to see thanks.
RE: zx14 stalls out
06/27/16 11:54 AM
Since it's been crashed,check the sidestand switch, the clutch switch and the tip over sensor. Any one of these can cause your problem. You can bypass the sidestand and clutch switch to eliminate them as a source.
