Thread: A really excellent wire connecting product
Created on: 03/03/19 05:43 PM
JimGnitecki
Vancouver Island, Canada
03/03/19 5:43 PM
This product makes it REALLY EASY to butt-connect 2 electrical wires of most common sizes:
https://www.amazon.ca/gp/product/B01LK2YJQC/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Really simple to use:
- Select the right size of connector given the wire sizes to be joined (the product package includes 4 different sizes that will handle virtually all automotive and motorcycle needs)
- Strip a SHORT (approx 3/8 inch) section of the end of each wire
- Feed the 2 wires into the opposite ends of the connector, making sure the 2 stripped sections of wire overlap in the centre of the connector
- Apply heat with a heat gun (NOT a hair dryer. You need the heat of heat gun)
The different sections of the connector behave as follows:
- The solder in the centre section metals and electrically joins the 2 wires
- The 2 blobs of plastic (one for each wire) melt to seal the wire mechanically into the connector AND to waterproof the connection
- The clear plastic tube shrinks to tightly enclose everything
I just used the second smallest size to connect my new LED license plate light on my ZX-14R to a 6” section of wiring with a factory connector salvaged from the old incandescent license plate light. Very fast, easy, and reliable. Much better than soldering and wrapping in tape, and way, way more reliable, and much physically smaller, than vampire or suitcase connectors.
Jim G
RE: A really excellent wire connecting product
03/03/19 7:26 PM
I have been seeing those advertised and wondered hoe they were real world.. Thanks ....
Nightmare
Nightmare's Gravatar
03/04/19 8:38 AM
JimGnitecki,
Those looks really convenient but how strong are the connections? Does it actually solder the wires together or is it a mechanical (eg crimp) connection?
03/04/19 8:48 AM
They are strong, they do solder and they are really easy to use. I have used them a few times now on my automotive wiring. Heat gun temp melts solder and shrinks the outer casing all at the same time to seal everything.
Dave
03/04/19 10:02 AM
Looks cool. I'm skeptical as to the reliability compared to solder though. Seems to me it would make a cold solder joint which is still a connection but not well bonded as it should be with a soldering iron.
Me personally, I think I would skip that product in favor of a good ol soldering iron for critical things like nitrous and PC5 electronics.
03/04/19 12:05 PM
if you're not yanking on the wires,looks good.
Eray
Eray's Gravatar
03/05/19 11:40 AM
They work great. Came with the Yoshimura Fender Eliminator Kit.
