Thread: Speedo Erratic
Created on: 04/03/10 06:48 PM
redtrace
redtrace's Gravatar
Speedo Erratic
04/03/10 6:48 PM
I noticed on my way home tonight that the speedometer needle was jumping around. It was jumping + and - 20 mph. I was keeping with traffic, so I guess that I was going around 55. After a full stop at an intersection, the needle came to rest and when I resumed, problem was gone. Anyone else have an issue like this happen? I do have a speedo-healer installed. Maybe something going on there. Thanks in advance!
RE: Speedo Erratic
04/03/10 10:14 PM
Healtech Speedohealer?I've got one.Never been erratic yet-might just reset it again to the current setup you've got-may be just a glitch in it's software.Sounds like it stopped working momentarily.V4 here as well JDC.
* Last updated by: blue07 on 4/3/2010 @ 11:36 PM *
JDC
JDC's Gravatar
RE: Speedo Erratic
04/03/10 10:49 PM
I had the same thing happen. Ended up being the Speedohealer V4. It was replaced and I have not put back on.
redtrace
redtrace's Gravatar
RE: Speedo Erratic
04/04/10 6:52 AM
Thanks guys. I have the V4 also. I'll try to reset it and see if it makes a difference.
bigjay44
bigjay44's Gravatar
Columbia, SC, USA
RE: Speedo Erratic
12/30/12 7:19 PM
What was it?
Only one bike that can make me leave suzuki after 11 years.
RE: Speedo Erratic
01/01/13 7:52 PM
hate it when they don't post the answer to the mystery.
5'll get you 10 it was the SHv4. Mine went bonkers on me last summer. No need to replace, I just make sure I don't get it wet. The thing started bouncing around and the fuel was cutting like I was hitting the speed limiter! Finally the speedo just went to 0 and stayed there. The bike ran normal w/out the speedo operating. Shut her off for a few hours. Came back and she started up, speedo worked fine.
Like I said, keep those inline connectors at the speed sensor lead dry. i wrapped mine with electrical tape. Still got a little stutter one time after a wash but not severe. At least I know what it is. Plan to install the Boneville this winter. The SH goes on the busa.
audioboyz
audioboyz's Gravatar
RE: Speedo Erratic
01/01/13 9:42 PM
I got tired of my Healer not working.Beat it with a hammer.Replaced it with a SpeedRD device.It's waterproof and works great.
Craig
2011 Mustang GT 6-Speed 5.0
RE: Speedo Erratic
05/16/20 2:42 PM
My Speedo inexplicably went berzerk for a minute then went to 0 and stayed until I shut the ignition off and turned it back on a few hours later.
I thought it was the speedo healer connectors getting damp. Could a loose countershaft sprocket nut cause the speedo to malfunction in this way on the Gen1?
