Thread: Handling vs Comfort: 55 Series Tire and Risers
Created on: 07/13/20 06:57 AM
tknj99
07/13/20 6:57 AM
Hi All,
I would like to explore options and opinions on how to make the R handle better. I've already addressed the comfort side of things as best as i could on my budget with stacked risers for a 2" rise. I have read that changing from the stock 190/50 tire to a 190/55 tire will raise the rear and allow better turn in with the only downside being high speed stability over 130+. As i am not interested in insane top speed runs on a regular basis, i was wondering what the compromise might be with the 55 series tire in combination with the bar risers. Would the rise in the back perhaps offset the 2" bar rise and then put me back in the forward lean position and introduce more pressure on the hands? or am i overthinking things?
I'd love to hear from those who have both the risers and 55 series rear tire and whether or not there were any detrimental effects introduced to the overall comfort level prior to the change of tire.
PS1: found a nail in my rear the other day right in the center of the tire and plugged it up and its holding with no issues, but it got me thinking about tires...
PS2: went on a group ride the other day with a few adventure bikes and i was pretty surprised at how well those things handle and make it around the curves; one was a Duc Multristada 1200 and the owner claimed it has 150hp.. crazy!
* Last updated by: tknj99 on 7/13/2020 @ 7:00 AM *
RE: Handling vs Comfort: 55 Series Tire and Risers
07/13/20 12:32 PM
Raising the rear increases the fork angle and shortens the trail a bit and those alone improve handling but decreases stability (more likely to oscillate). However, I believe the improved turn in of a 190-55 is mostly do to the elongated profile rather than the more circular profile of a 190/50.
A circular profile puts the center of the tire farther out of line with the center of the motorcycle when the motorcycle leans. The wider the tire is the more out of line with the bike it becomes as the lean increases. An elliptical tire profile behaves like a narrower tire because the elliptical profile IS narrower where it is contacting the road as you execute turning in. Picture an egg standing on end and ping pong ball. Place your finger on top of both, which one of those will roll to the side easier? The egg will and the vertical axis of the egg will also remain closer to the vertical axis of your finger. The ping pong ball will be way off the vertical axis of your finger. Get it? I'd post a picture but my pics are are filled up on the forum.
After you have executed your lean, you are riding on the flatter side that elliptical profile has. This gives you a larger contact patch which theoretically should not provide better traction than a small contact patch. In practice however, the larger contact patch (elliptical profile) definitely does improve traction over a small contact patch (round profile). A lot of factors other than surface area come into traction of a leaning motorcycle.
If you use a 190/55 to improve handling, you are probably safer to get one that is somewhat track oriented. All the 190/55s I have used were street/track tires designed primarily for track use. They all made the bike tip in easier. They all were noticeably more eliptical in profile than the stock tire. The only exception was the latest which is the Bridgestone RS10 200/55. Don't get that one, it has a very round shape like the stock 190/50. I don't know what luck you will have with 190/55s if you use a more street oriented tire. Street tires are meant to provide long life which requires harder, less grippy rubber so designing that tire for extreme lean angles would not be a priority.
I use a 200/55 and they are even better than 190/55s. The bead seats well to the rim, I've never had a problem loosing air. I also use slicks and they work great on the street as long as I avoid rain. I'm very careful about dust and gravel too but for hard leaning, I would be careful even with a DOT tire. Slicks are less expensive than DOT tires of the same manufacturer/compound. A 200/55 is heavier than a 190/55 by about 1 lb which is the main disadvantage.
I've done 180 mph on a 200/55. It's perfectly stable. I use a steering damper but I doubt it ever comes into play riding in a straight line. Not much cornering either but I have noticed a a slight whip in the steering ocassionlly with the damper off. Raising the rear 4 or 5 mm with a 190/55 is not going to affect your fork angle enough to make the bike less stable at any speed.
Not noticeable, see above. If you are tippy-toeing it with a 190/50, you will notice that when you put yout feet down, especially when the 190/55 is new.
Pirelli Super Corsas!!! 200/55 if they have it!!!!!!! I'm using Metzler Racetec RR Comp K Slick 200/55 on the busa right now. It's almost as good as the Pirelli slick I had and that was basically a Super Corsa without sipes.
I had the same experience with the same bike. I could have crashed chasing him, I was in over my head but I hung on his tail. I'm sure he was outpacing me. Don't think you'll ever transform this big beast into one of those bikes but if you know the road well, that will help more than a taller tire. Don't get anyone to crash their bike LOL. I'd rather just stop and talk.
* Last updated by: Rook on 7/13/2020 @ 12:35 PM *
tknj99
07/13/20 1:22 PM
As always, great information, thanks Rook.. I'm pretty sold on the 190/55 for my next tire
07/13/20 8:20 PM
I have 1" bar risers and use a 190/55. Bike handles great at every speed I've
tried. Just wish the rear tire would last longer.
tknj99
07/14/20 6:59 AM
I guess the trick will be to find a 190/55 that has long life and handles great without breaking the bank... wondering about Shinko? ive run them on a former cruiser and was a great alternative to the more expensive Metzeler but ofcourse apples and oranges in this case :)
ominousone
Twin Cites So Burbs, MN
07/14/20 9:02 AM
I've run the 010 Apex, 011 Verge, 005 Advance, 009 Raven, all with no issues on my old Blackbird and my 2016 ZX14R SE. I tend to get up to maybe 5k miles on the rear, more on the front. I've ridden many 600-700 mile days, as well as many miles on the Dragon and twisties on that neighborhood. They handle fine in the dry and wet, stick fine in the curves and the price can't be beat.
ominousone
tknj99
07/14/20 10:22 AM
Thanks for that info, great to know
07/15/20 10:47 AM
Im a tire whore. I'll use just about anything. I've run recaps even.
Right now I'm budgeting. I'm currently using Conti Sport Attack tires. Really like
the way it handles. Softer carcass so it absorbs bumps better. Worst part is rear tire life
is not outstanding. But at $125 for a 190/55 from Cycle Gear, I can deal with it.
07/15/20 10:55 AM
I've recently been "very" impressed with.....
Bridgestone Battlax Sport Touring T31
Around 250.00 a set.
Watch for rebates, usually can get for around 200 after rebate.
Blkcasper
Blkcasper's Gravatar
08/20/20 10:15 PM
seriously don't go cheap on tires. There are so many great tires out there that will get you great mileage and handling. I personally have been through many different brands of tires. Bridgestone's, Michelin, perilla ect.
Really all depends on how you ride, mileage you put on the bike, road conditions where you live. I have 3 bikes and I average average about 10K miles a year on all 3 of my bikes, commuting, track days, very nice twisty back roads every other week.
My personal all around favorite tire rite now is the Michelin Road 5. I had the road 4's and even did track day on the. Awesome tire. believe it or not I average 10k plus miles on a set. I have 3 bike so tires can get really expensive.
Yes the are pricey, but only have to change one set of tires per year vs every 3-4 months is very cost effective.
When I get some free time I'll post pictures of tire ware after track days and commute mileage
Luvin My ZX14R'S.
SteveStLaurent
SteveStLaurent's Gravatar
09/07/20 12:55 PM
Ditto to everything Blkcasper said. Tires are not the place to cheap out. The Road 5's are the best street tire I've ever ridden on (and better than track tires from years ago). I'm pretty hard on tires, I got 7,200 miles out of my last set but that's more than I've ever gotten out of a tire.
The handling difference between the stock tires and the Road 5's is incredible. There's more to handling than just the size of the tire. The Road 5's are very neutral, you can crank it over and then relax and she'll just sit there until you open the throttle. The stock tires you had hold down otherwise it wanted to stand up on it's own. Same size tires.
streetsweeper
streetsweeper's Gravatar
09/08/20 1:03 AM
even tho blckcasper runs nice tires he still crashes his bikes alot, on the other hand mad the cheap tire whore runnin 2nd hand tires out of the shops dumpsters, manages to keep it shinny side up, and has lots of fun. I really dig my lsl speiglars and knights design footpegs, ypo really get nice visuals of your gloves in the rear view mirrors tho.
you also better get tucked before you hammer down if your somewhat upright or else you can get ripped off the bike. like charley say, get under the paint.
* Last updated by: streetsweeper on 9/8/2020 @ 1:09 AM *
