Vic, LOL, I think we have our threads crossed. This belongs in the gas cap thread, NO? Chinese quality may be worse as far as metallurgy. I read about a test conducted on Chinese levers compared to Pazzo and the metal was probably slightly inferior in the Chinese lever but of no real significance. Color, YES. Not consistant. The yellow anodized sliders I have look like a cheap attempt at aproximating gold in the online photos. They are yellow orange. The blue levers I bought are light blue which is too different from the other blues that seem to be more or less standard on anodized parts.
Any aluminum bolt will be a lot weaker than steel. I never tighten them more than about half the spec of steel. I broke off a Pro Bolt Ti steel screw to my front rotor. It was a small one (5mm I think) but it should have taken 20 ft lbs of torque. Was my mistake, I used the stock torque spec which is for a 6mm steel bolt.
Fill the fuel tank as high as you can to minimize atmospheric ingestion due to temperature change. That'll keep the fuel from oxidizing and the water out of the tank.
That's what I usually do. I heard high octane gas might leave behind sediment if it sits a long time. I used to store with regular gas for this reason but now I'm wondering if it's worth the risk of predetonating when the bike is taken out of storage. It's probably more important to store with gas that has little or no ethanol if you can. I fill mine up past the splashguard but not so high that it can seep into the rubber gaskets on the cap. Also, there were issues with paint starting to peel around the gas cap ring. That was years back and I don't know what the cause was.
