Thread: Hardened
Created on: 11/19/20 12:52 PM
skewedTotheLeft
skewedTotheLeft's Gravatar
Hardened
11/19/20 12:52 PM
Just got my bike from Johnny Turbo's shop (Exoticycle). Holy Mother of Jesus! He put Wossner pistons, rods coated the pistons and a few other things. She starts off on low boost 245 RWHP and when I hit the high beam she jumps up to 319 RWHP. It's like being strapped to a rocket!
* Last updated by: skewedTotheLeft on 11/19/2020 @ 12:59 PM *
2013 ZX-14R Stage 1 Turbo (319 RWHP)
RE: Hardened
11/19/20 5:51 PM
50% increase in Power !! Where did I leave my checkbook ?????
RE: Hardened
11/19/20 6:48 PM
NICE!
skewedTotheLeft
RE: Hardened
11/20/20 11:20 AM
I picked up a 5 gallon pail of C16 Race fuel ($100). I'm going to run a 50/50 mixture of 92 non-ethanol and C16 which is 117 octane so that will be .5 * 92 + .5 * 117 = 104.5 octane--that should stop any type of detonation no matter how hard I push her.
RE: Hardened
11/20/20 12:35 PM
I do not think my checkbook could handle that one....................
Fordtech58
RE: Hardened
11/21/20 6:13 PM
Would you care to share what the boost levels were for each of your power levels? What were you using for fuel on the dyno pulls? I assume not intercooled? Hope it's not to much to ask. Aloha, Rick B...
skewedTotheLeft
RE: Hardened
11/24/20 6:08 PM
Hi Fordtech58,
low boost is 6 and high is at 9. He dynoed it with 93 octane pump fuel and yes it is NOT intercooled.
* Last updated by: skewedTotheLeft on 11/24/2020 @ 6:13 PM *
Fordtech58
RE: Hardened
11/24/20 10:04 PM
That's great power for 9 psi! Good luck with it. I can't imagine trying to keep the brain attached to the right wrist street riding that beast. Stay safe and Mahalo for sharing the information, Rick B...
bobk
bobk's Gravatar
RE: Hardened
11/27/20 3:44 PM
With rods and pistons why is he keeping the boost so low. You can easily run 15lbs and be in the mid 300s and with your mixture of fuel "too expensive to run all the time" IMO you could be in the 400hp range.Is there something I'm missing?
Ft. Lauderdale
skewedTotheLeft
RE: Hardened
11/27/20 5:07 PM
Bobk this is a street bike plus he wants me to get use to the power before he takes me up to 400 RWHP. On the street, as you know, with a simple flick of the wrist, you break traction and are in the rev limiter--not so at a well-prepped track.
* Last updated by: skewedTotheLeft on 11/27/2020 @ 5:08 PM *
bobk
bobk's Gravatar
RE: Hardened
11/28/20 6:22 AM
OK, I understand. Makes perfect sense I just didn't understand what the plan was. There is no doubt traction is a major problem with these bikes, but WHAT a problem. Like Romans has always said, once you go boosted you will never go back!
Ft. Lauderdale
bobk
bobk's Gravatar
RE: Hardened
11/28/20 6:27 AM
Are you planning on stretching the wheelbase?
Ft. Lauderdale
skewedTotheLeft
RE: Hardened
11/28/20 8:58 AM
I'm at 6" over with a Roaring Toyz swing-arm, but Johnny says that won't be enough when he takes me up to 400 rwhp.
