Rook ... Thanks for the explanation!
Amazing to think we can now time the ignition differently from one gear to the next ...
Yeah that is cool that it's possible to adjust timing/gear with a flash. Fueling works the same way, there's a separate map for each gear. A TRE prevents the ECU from recognizing any gear changes and keeps the mapping for timing, flies and fueling on N or 6 which have no restrictions.
It's always been possible to adjust fueling and timing / gear with a PC5 and Ignition Module but few people wanted to mess with all of that. The timing aspect is kind of obscure. Nobody knows the exact timing corrections for any gear except for Ivan and Guhl. The timing curve I described is safe and improves power but you have very small changes in timing / rpm and TP just as you do with fueling. We don't know for sure what those exact numbers are. Here is a Gen1 timing map. As I understand it, the ECU uses this same map for every gear but adjusts the timing for gears 1 through 4 differently for each of those gears.
Here's more info on that if you care to read.
Anyway, if it's optimum performance you're after, it's doubtful there is much if any benefit to having mapping/gear. The timing, flies and fueling that create the most power for 1st gear are the same for every other gear. Using a TRE to lock into a gear map that has no timing restriction (5, 6 or N) and then tuning fueling optimizes power for every gear equally. I suspect most flashes achieve the same effect by unifying the gear mapping for fueling. You still have 6 fuel maps but they are duplicates. I also suspect most flashes use a timing curve such as I described in my previous post. They don't know the exact number of degrees the timing is retarded or exactly what corrections the ECU makes/gear so they go by a generally accepted pattern along with what they can determine by dyno tuning. Romans seemed to feel the basic timing curve I alluded to was good for all gears. He was not into mapping/gear--at least not with a PC5 and Ignition Module...maybe he did it with his flash though--IDK.
