Danno, ours came split from the manufacturer: Link
Superman, I mounted my compressor on the LH side, behind and under the ram air tube:
I mounted the horn between the RH inner and outer fairings, using a custom bracket to attach it to the outer fairing, like so:
I did take off the round cap on the side facing us in this photo, which allows the inner fairing to fit back on with almost no flex. Finally, I drilled a grid of holes in the inner fairing to allow the horn to flow through. Didn't want to have to modify plastics, but you will never see it under normal circumstances. I also didn't want to take the chance of crushing the horn, fender, or radiator during a sudden application of braking in the stock position.
* Last updated by: TigerFire13 on 2/28/2016 @ 7:38 AM *
2013 Pearl Stardust White ZX-14R
Two Brothers 4-2-1 Carbon Fiber w/ Ceramic coated headers, Sargent Seat, Rostra Cruise Control, Oxford Heated Grips, Murph's Pegs, Denali Soundbomb, SW-Motech PLX Contour racks and Alu-Rack, Givi V35's and V56 w/ Kawi OEM trim, Fenda Extenda and Puig Hugger.
