Thread: Hid Install help....DDM Kit
Created on: 08/01/09 05:36 PM
SnuffyZX
SnuffyZX's Gravatar
08/01/09 5:36 PM
Hello All
I just install a set of Hid's on my bike followed the directions to the letter from DDM and got no results has anyone else had a similar experience and if so how did you fix the problem?
Any Help would be great.
2012 Golden Blazed Green SE
Brocks Titanium Alloy CT Dual's
CBLASTED!
Brocks Ohlins Steering Dampner
Ohlins KA544 Rear Shock
MRA Touring Windscreen
Power Bronze Hugger
Muzzy Fender Eliminator
DDM 55w HID's
COX Radiator Guard
Clear Alternatives Intergrated Tailight
HyperLight Flashing Brake lights
Radar/Laser Detection & GPS with Radar Screamer
2007 Candy Plasma Blue (Retired)
RE: Hid Install help....DDM Kit
08/02/09 12:23 AM
Snuffy-you need to make sure the hot leads are going to the hot side,and the grounds are going to ground side.If they're not coming on,one or more of the plugs is connected backwards.The small plugs-you can't get those wrong.But the bigger ones-especially that one that plugs to the lamp and stock wiring plug(where the ORIGINAL lamp plugs into)-that one I think can be put in backwards-and it won't light.Just don't change em with your bike key on, or running.You may get the surprise of your life!!!
* Last updated by: blue07 on 8/2/2009 @ 12:30 AM *
Steven14
Steven14's Gravatar
08/02/09 7:33 AM
I wonder how do you know Blue?
'09 ZX-6R
'94 ZX-11
'07 ZX-14
'08 Vino 125 (hers)
SnuffyZX
SnuffyZX's Gravatar
08/02/09 10:49 AM
Thanks Blue
I will give it another shot today...so the plugs that DDM comes with may have to be switched in order to make it run right? The kit has the type of plugs that seem like they have to be plugged one way and one way only so I may have to reverse the way they plug in?
Again
CBLASTED!
Power Bronze Hugger
DDM 55w HID's
COX Radiator Guard
08/02/09 11:08 AM
NO STEVEN LOL-I didn't jump start meself.!!!Just thought I'd give him a friendly heads-up!(Who wants to start their day with shock treatments!)Ya-Snuffy-you can try that and see.If they're not coming on AT ALL-it's usually the leads are crossed.If they're coming on "some",then it's most likely the contact in the connectors-that's what was going on with mine anyway.Sounds kinda funky,but I ended up removing the plastic plug(the two prong one that goes into the lamp lead stock connector)and just inserting the prongs into the "light green"connector(as well as the "light blue"connector).That's the connection that can get backwards.So I tried it one way,that didn't light up.Then I reversed it,that solved it.Had to do that on all four lamps.Then once they were coming on,I siliconed the plugs and prongs in there-they work fine now.Go figure-you'd think they would work okay right out of the gate-I suppose a lot of guys here have em work fine.Mine were finicky,that's for sure.I mean,when I installed em and they were hanging outside the bike to the sides-they came on just fine.As soon as I inserted the lamps into the lenses,two of em wouldn't come on(only intermittently).Geez.
* Last updated by: blue07 on 8/2/2009 @ 11:22 AM *
SnuffyZX
SnuffyZX's Gravatar
08/02/09 12:44 PM
Thanks Again Blue
Its pouring rain her in N.Y.C. so I can't mess with it right know but thanks for the help...i will try what u said as soon as I can get the bike apart again. I will let U know what the end result is....Ride Safe
CBLASTED!
Power Bronze Hugger
DDM 55w HID's
COX Radiator Guard
08/02/09 1:33 PM
You'll git er!You ride safe in the rain there!!!(you may be able to get her to work WITHOUT doing it like I did).But I tried using the plug housings on there,and couldn't get a secure reliable contact.
SnuffyZX
SnuffyZX's Gravatar
08/02/09 4:52 PM
ALL I HAVE TO SAY IS Blue07 came through in a pinch!!!!!
I check the positive and negative wires to make sure they where pluging in the right way and U were right they were not the connection they send is backwards so I did like You said and turned the conections around like U suggested a then there was LIGHT....Bright Azz Light.
Thanks Again For The Help....I was losing my mind yesterday when they wouldn't lite.
CBLASTED!
Power Bronze Hugger
DDM 55w HID's
COX Radiator Guard
mre14
mre14's Gravatar
08/02/09 6:22 PM
so are they just plug and play or do I have to do something extra?
1995 ZX-9 custom paint; 2008 ZX-14 Atomic Silver 2018 ZX-14 Grey Black Orange you glad I didn't say yellow
mre14
mre14's Gravatar
08/02/09 6:46 PM
nevermind just figured it out and had the same problem....plug was in upside down!!!
SnuffyZX
SnuffyZX's Gravatar
08/02/09 8:36 PM
Hey MRE14
Yes the connection has to made upside down to connect pos to pos and neg to neg.
Thanks Again Blue07 for the install help.
CBLASTED!
Power Bronze Hugger
DDM 55w HID's
COX Radiator Guard
SnuffyZX
SnuffyZX's Gravatar
08/02/09 8:44 PM
Oh by the way took the bike for a spin as soon as it got dark tonight and all I can say is I should have done this mod sooner....crazy bright....when i put my hi beams on i cant even tell there on the low beams are so bright.
CBLASTED!
Power Bronze Hugger
DDM 55w HID's
COX Radiator Guard
08/03/09 12:19 AM
Glad that worked for ya!Enjoy and Ride safe!Don't fergit-you're gonna blind the oncoming cars at night there!!!Don't want em to run into ya!!!
mre14
mre14's Gravatar
08/03/09 11:49 AM
so another quick dumb question...well maybe not so dumb....ok so I have those installed now I am trying to find that adjusting screw to raise the headlights a bit....
* Last updated by: mre14 on 8/3/2009 @ 4:00 PM *
SnuffyZX
SnuffyZX's Gravatar
08/03/09 7:36 PM
Hey Mre14
Here is the link you are looking for to adjust your lights:
http://www.zx14ninjaforum.com/messages.cfm?threadid=57764EDC-1372-66AE-3B585485EA921C29
Ride Safe
CBLASTED!
Power Bronze Hugger
DDM 55w HID's
COX Radiator Guard
mre14
mre14's Gravatar
08/03/09 7:42 PM
Thanks Snuffy and Blue,
The lights are in and I even stopped at my local Smautozone to pick up one of those blue 194 bulbs to put in!!!! came out great, though I am going to look for a better 194 bulb!!! any additional info on where I can get a better 194???
Thanks again!!!
* Last updated by: mre14 on 8/3/2009 @ 9:21 PM *
SnuffyZX
SnuffyZX's Gravatar
08/04/09 8:52 PM
AnyTime Mre14!!!!
The real Thanks Goes To BLUE07
I just ordered new 194 bulbs from the following web site:
http://www.lite-eyes.com/
They had a few different choices.
CBLASTED!
Power Bronze Hugger
DDM 55w HID's
COX Radiator Guard
08/05/09 1:02 AM
