Thread: Luggasge setup for the 14
Created on: 05/11/13 05:09 PM
stevie14t
stevie14t's Gravatar
Luggage setup for the 14
05/11/13 5:09 PM
So my bike came with racks, but no luggage. After borrowing a few pieces from other bikes, I think it's almost there. Not to sure about the top case though, may change/lose it.
At least my shit will stay dry when it rains.....it always rains.
What does everyone use for tank bags? I have a small magnetic one but it doesn't like the tank on the 14, so I'm off looking for non magnetic one.
* Last updated by: stevie14t on 5/11/2013 @ 5:28 PM *
Dave905
Dave905's Gravatar
RE: Luggasge setup for the 14
05/11/13 8:24 PM
Hey Stevie
I use a Alpinestars Manta tank bag for little stuff (cameras, wallets, key, etc.) and a MotoPak GT-20 for overnight rides that holds a lot of stuff. Both are magnetic and no problems at any speed.
You having trouble with magnetic ones?
Twisted Throttle also sells Bag Connection Tank bag systems. It's a ring that attaches to your gas tank and their tank bag clips on it. Nothing touches the paint.
Check it HERE
* Last updated by: Dave905 on 5/11/2013 @ 10:58 PM *
Sometimes the sun shines around the clock.... but sometimes it's dark and Hell is hot.
SunOfAbyss
SunOfAbyss's Gravatar
05/11/13 8:56 PM
I don't know if that top case is just dirty or the paint is messed up. If it is paint, they sell black trim paint in a rattle can that has a little texture and will make that look like new again.
Motorcycles are perfectly safe, as long as you don't fall off and you don't get hit by anything...
stevie14t
05/12/13 8:22 AM
The top case used to live on the klr so it's just mud.
Might replace it with this one...
Just looks more 14ish?
darryle
darryle's Gravatar
05/14/13 3:41 PM
this works for me
dragking
dragking's Gravatar
05/15/13 11:04 AM
Beautiful shot Darryle!!! Makes me wanna take off for a couple of days! I'm a soft luggage tourer myself, looks better on fast looking bikes in my opinion. Kriega US-40 in the back, Kriega backpack or waist pack and I'm planning to get a Bagster tank cover with tank bag
Twt14
Twt14's Gravatar
06/11/13 7:30 PM
Dave905
Dave905's Gravatar
06/11/13 7:44 PM
Twt14
I came so close to buying that same trailer 2 years ago!
Welcome to the forum fellow Ontarian
Danno's Gravatar
Southwestern Illinois
06/12/13 3:42 PM
I have an old EXL magnetic expandable tank bag I bought used off Fleabay because I liked how the blue stripes matched the bike. Got a strap in front so I can sling it off to the side and access the spin-on gas cap when it needs fuel.
Since the original map pocket was missing, I adapted one I found in the Twisted Throttle catalog.
* Last updated by: Danno on 6/12/2013 @ 3:47 PM *
stevie14t
06/12/13 5:05 PM
Neat trailer sometimes I think that the way to go for the dogs...but I'll probably go with a hack...means another bike!
Danno, what is the toggle switch on the right side panel for?
PS ......like the colour matched pipes!
* Last updated by: stevie14t on 6/12/2013 @ 6:18 PM *
robertv19
robertv19's Gravatar
Cambridge, Ontario
06/12/13 6:37 PM
+1 on the Bags Connection tank bag
I think Cortech makes a similar setup now, but I can't vouch for it.
I have the BC Daypack and definitely like the fact that it doesn't touch the tank.
It pops off easily enough when you need to fill up etc. but is very secure when attached.
Fit & finish is top notch as well.
Worth the $, IMO.
Twisted Throttle (read: candy store) has them.
Cheers,
Rob
Danno's Gravatar
06/12/13 6:43 PM
Danno, what is the toggle switch on the right side panel for?-stevie14t
Just a lighted switch for the power source for the radar detector. It's a dual cig lighter plug with 2 USB power ports. Mounted just out of the picture in front of the right grip under the upper corner of the fairing.
The white light in the center is the port where I plug the detector in. The USB outlets are visible on the left. The red light on the right is a small rechargeable flashlight I leave plugged into the outer cig port. When it's on charge, the red LED glows.
* Last updated by: Danno on 6/12/2013 @ 6:50 PM *
stevie14t
06/12/13 6:58 PM
Cool....you don't hit it off and on with your knee?
Danno's Gravatar
06/13/13 4:45 AM
If I don't have it on and my knee hits it, the r.d. beeps in my earbuds, so I know I did. With the lights on the outlet and the light of the r.d. it's pretty obvious whether it's on or off. Happens once in a while. I didn't want to drill the c-f inner fairing panels and the current location is the only place there was room for the wires and the back of the switch on the foremans.
06/13/13 4:54 PM
Hey Twt, I need all the info on that trailer. We used soft saddlebags on our Oregon trip, had the straps under the seat and ended up cracking my bodywork mounts. A trailer like that would carry more stuff than both our saddlebags. And I use an expandable magnetic tank bag with no attachment problems at all.
