Page: 1 2 3
Thread: Turbo map for BAZZAZ
Created on: 10/07/11 01:47 PM
dalmau11
10/07/11 1:47 PM
Need a map for a Turbo ZX-14, stock motor, no more than 7lbs. Bazzaz Z-Fi. TRE. Thanks. email cqdalmau at yahoo dot com
RE: Turbo map for BAZZAZ
10/09/11 8:00 PM
Yikes, can't help sorry. PCV or 3
spoedniq
spoedniq's Gravatar
11/03/12 12:11 PM
Could you posibly send me the map for the PCV?
I'm busy with the last bits om my turbo convertion on my zx14r and can do witn some help please.
Stock motor, with 5psi of boost, and will be using pump gass.
Any help would make my life a whole lot easier as I'm from South Africa.
11/04/12 4:59 PM
14R,,,,, 2012 ????
You did not leave a E- Mail address ?
spoedniq
spoedniq's Gravatar
11/05/12 8:58 PM
Yes its a 2012 ZX14R.
Email: jaco.spoedniq@gmail.com
Thanks for the help :-)
11/06/12 3:09 AM
5 psi, I have nothing, but will send you a couple to look at. What Turbo are you using ? Fuel pressure ? How are you reading AFR, Auto Tune ?,,,, More info needed. These maps I'm sending are for study ONLY and will not work so be careful. Cheers.
Post some pictures of your build.
spoedniq
spoedniq's Gravatar
11/06/12 12:58 PM
I'm using a T3/4 with a .63 exhaust housing.
For now ill be using the standard pump, but have started looking for stronger ones.
You will see in the pixs i send you is the gauge for the AFR sensor.
I got the PCV and the Ignition module to pull the timimg back. From what i have heard 4 is enough for when it comes into boost???
Lol and sorry i ment im going to be boosting 0.5bar and not psi so im looking at about 8/9psi....
Okay i will try the photo upload thing lol but dont know if ill come right....
spoedniq
spoedniq's Gravatar
11/06/12 1:16 PM
spoedniq
spoedniq's Gravatar
11/06/12 1:18 PM
This is how far she is... I took here to the guy thats going to do the welding for me so hopefully by the weekend i can start installing the last bits....
11/06/12 6:53 PM
Yikes,,, you will not get a second chance to fix fueling issues, you must do Now or Boom
spoedniq
spoedniq's Gravatar
11/06/12 9:17 PM
Oky i will get a better fuel pump and install it before the time.
Would i need a fuel pump regulator as well or is it not needed?
11/07/12 3:43 AM
Both, a fuel pump and a regulator are a must have. Make sure you have all your gauges in place so you can see them. First ride is the most important.
spoedniq
spoedniq's Gravatar
11/07/12 10:03 AM
At what fuel pressure you run?
Also do the pressure increace if it goes into boost?
spoedniq
spoedniq's Gravatar
11/07/12 10:33 AM
Okay sorry i only saw now the problem you had with your pump. I will do the same as what you did to make sure i got sufficient fuel pressure!
11/07/12 2:37 PM
Good call. Fuel pressure and a good tune are the key to boost enjoyment. Take you time and keep the pictures coming. Who's compressor ?
spoedniq
spoedniq's Gravatar
11/08/12 11:04 AM
Its a friend of mine that has a turbo shop. He bilds good reliable turbos all with Garrett internals and turbo is also VSR Core Balanced. So I'm more then happy with it.
I will start a new chat once i get the bike back from the welder and upload some more pix.
Have you been on the strip with yours? Whats your best time?
11/08/12 4:08 PM
T3/T4 Sleeve bearings ? Or was it possible to make it with dual ball bearings ?
Not with Turbo bike. I work most weekends so it's not easy to make time for the track. Not to mention it's 2- 1/2 hours each way. Last time there, spent all day only got 3 runs in. Grrrrrrr.
spoedniq
spoedniq's Gravatar
11/08/12 9:19 PM
Yes it is a T3/4 but not a dual ball bearing....
I was hoping to start putting her togerher this weekend but Im also working, will have to make time :-)
spoedniq
spoedniq's Gravatar
11/20/12 11:41 AM
Just a quick question for you Romans.
What els do you run with the PCV? Auto tuner and do you have the boost input unit from powercommander?
11/20/12 8:28 PM
I do have a pressure 5 volt input from AEM boost gauge but do not use it for mapbuilding
spoedniq
spoedniq's Gravatar
11/24/12 12:02 PM
Romans Imneed your help agail plz.
I bought a bigger and stronger fuel pump today, i also got a external fuel pressure regulator.
Now my question is how do i pipe up the system???
I see there is only one outlet from the tank and only one inlet on the fuel rail.... There is no fuel return from the rail to the tank.
Do i need to have a fuel return after the regulator?
It is a 300L/h fuel pump.
spoedniq
spoedniq's Gravatar
11/24/12 12:23 PM
Do i need to make a new hole and pipe for the return?
11/24/12 2:02 PM
Yes, reg after injector rail and return from reg to a hole you make in the tank,,,, or plate with a in and a out.
Yes, easiest way IMO.
spoedniq
spoedniq's Gravatar
11/24/12 10:15 PM
Thanks I will do that
11/25/12 8:24 PM
Who's pump,, Walbro ?
Who's regulator ? One to one ?
Pictures please. My 2012R build starting soon. Fresh ideas always Good.
Page: 1 2 3
