Thread: How to break in a new 14R
Created on: 05/10/18 05:27 AM
RE: How to break in a new 14R
05/10/18 12:38 PM
Sit on bike as if sitting on your computer chair.
With the right grip, right click over 'Explainer vid studio' when you see the hand over that hot link.
The right end of the dash screen will have a gray line over H Tea Tea Pee, forward slash, forward slash, jobs dot vidzzy dot com and you now start the bike up for break-in.
At the mode button, type 'vidzzy dot com' on what are you doing here?
Dis way used be spamboy, joe valgalvanized.
And data is how you break-a your chops is one post at a time.
paulbe
05/10/18 5:53 PM
Joseph--congrats on the new bike! Many will disagree, but your owner's manual tells you exactly what to do. I figure KHI thought of the engine, designed it, built it and warrantees it--so they must know SOMETHING! They want you to have a good experience on the bike, so they give you a modest break-in period. It goes by quickly and then you're free to rev it up.
Good luck!
Paul
05/10/18 7:50 PM
LOL HUb.
Okay Joseph.You want to start out gently in 1st.After Hub's instruction that is.Then you want to open wide open.Shift quickly to keep up with the r's.Hold throttle on the limiter for at least 10 seconds.That way,when you pull up next to someone,you know she'll rev bomb awesomely.Make sure within the first 600 miles,you hit the limiter at least 4 times during any given ride.And that means,in every gear as well.You want to really set those rings and get the crosshatching smoothed out ASAP.That's the best way I know of.
05/10/18 11:24 PM
Joseph, I will gladly sell you the real secret to proper break in. $50.
step 1 is totally free!!!
How to break in your motorcycle
05/10/18 11:31 PM
step 2
