So, after picking up the zx-14 in November, I’ve been in the process of setting it up for some sport-touring in order to replace the FJR. It came with heli risers and so far that’s all I’m going to need ergo-wise. That made the first order of business to add a cigarette outlet to power my garmin, phone charger, etc. I use this to plug in the battery tender as well. I made a bracket that utilizes the same bolt that attaches the brake reservoir to mount the plug. Next was installing the nuvi mount using the steering stem hole and ideas from the forum.
Luggage was next on the list. I had planned on using some FirstGear soft luggage in almost new condition I had from a previous bike. Then I heard the problems people had breaking the rear fairing mounts by letting side bags rest up against them. I love the givi hard case set up but did not want to fork out the $800 and let the soft luggage go to waste. After seeing pictures of some homemade standoffs, I decided to make some of my own. After a couple days of head scratching, bending and welding and about $30 in material I came up with these standoffs and thought I would post in case anyone else could find useful.
Started with side arms that bolt into the mount above the exhaust hanger that accepts a 10MM bolt:
I then installed a center bracket above the license plate that ties the two reflector arms together. That allows the side arms to be tied in to the center bracket for lateral support. The center bracket can stay even all the time, even with rack removed:
I added another support that comes off the exhaust hanger bolt. This takes most of the vertical load and keeps it off the rear bracket and fender.
Added some L brackets to support the luggage:
And a couple shots with the bags on:
A little more welding, grinding and a coat of plasti-dip will wrap it up. Each side attaches with three bolts and takes a couple minute to install or remove once you get to your destination. It can also be removed completely with no signs it was ever there. Best thing is no chance of damaging your body work, having to adjust velcro straps or worry about you bags shifting while riding. A little wider than I had planned but it'll do until I decide if I want to upgrade to the hardcases.
Add a tank bag and this is more than enough room for me for a week or so.
