Went from 17 teeth to 16 front sprocket...left rear stock at 42 teeth. Immediately had STUDDER...which means is seems like the engine is missing....bucking a bit up to 35-40 mph...after that it is a monster.
So, Don Guhl in Pa has the computer fix for this issue, and is the only man to figure out how to reprogram the ECU to make it work smoothly and properly removing the STUDDER. For those of you who have done a sprocket change....you will have to feather your clutch continuously at low speeds in traffic to manage forward movement...a real pain in the butt.
So anyone changing sprockets, give Don a call and he will tweak it for you and you can enjoy lots quicker acceleration and throttle response.
Ninja
