Thread: how to flush radiator.
Created on: 06/17/09 02:59 PM
karam242
06/17/09 2:59 PM
how to flush the radiator ? cant find the drain nut on the radiator. picture would be helpful, because service manual states nothing about draining radiator or bleeding brakes.
CoolWhip
CoolWhip's Gravatar
Brewtown Metropolis
RE: how to flush radiator.
06/17/09 3:21 PM
Karam, your really up to bat today and I can't seem to get to work.
OK the service manual is HERE. There are pics documented & everything related is there. Take off the applicable 10mm bolt on the water pump and drain the fluid. Easy cheesie, sort of...well, you do have to remove a few pieces of tupperware. You certainly are having fun today!
P.S. don't forget to change with a fresh copper gasket.
karam242
06/17/09 3:34 PM
thank you coolwhip. that manual was exactly what i needed. i felt guilty of dropping the bike from side stand so now i am taking care of it and fixing everything that needs to fix and replacing all fluids.
06/18/09 11:15 AM
You DID WHAT? KARAM!!!!How COULD YOU!!!(bad Karam,bad Karam)
* Last updated by: blue07 on 6/18/2009 @ 11:18 AM *
