Here's one of many threads where this little gem is mentioned.
The MightyVac.
Detect a note of sarcasm? I've run my mouth off on stuff prematurely in the past so I'm withholding final judgement until I try this thing on the lines. All I can say, for refilling and bleeding a dry master cylinder......? The traditional pump up the lever and crack the bleed works SO much better. The MityVac wasn't gettin 'er done. Just a little hiss of air sucking past the threads and a weak, barely noticeable trickle (if you could even call it that) of fluid. NOt nearly enough to fill the plastic tube. I tried a turkey marinade syringe and it actually created and sustained a lot better suction. (NOt only that, it makes the breast meat as juicy and delicious as the thigh meat...and it's fat free! Creole Butter. Highly recommended).
Dogo raved about it and several others swore once you used it, you'd never bleed brakes the old way ever again. What's been your experience with the MityVac?
