Thread: Battery Removal and Shorai 14 Ah Install
Created on: 04/26/12 09:20 PM
04/26/12 9:20 PM
Gen1 OEM Battery Removal
The OEM battery will need to be removed for maintenance or to connect battery maintainer pigtails. The OEM battery will also need to be replaced, usually after 3 years of service if well maintained. I recommend a Shorai battery for replacement. Refer to the second half of this tutorial for information on Shorai batteries.
Tools:
5mm hex tool.
8mm socket
phillips head screwdriver
dialectric grease
Removal
1. Remove the right Foreman (see FAIRINGS REMOVAL, Formans).
2. Remove battery door using a 5mm hex tool to remove the bolt (marked yellow in pic). Pull the projections from the grommets inside of the battery door.
3. Disconnect battery negative terminal (marked with a blue dot in step 2 pic, above) from frame using an 8mm socket. To avoid sparks which may ignite gasoline vapors, make certain that the cable and connector cannot contact or arch to frame.
Temporarily wrapping the eyelets with electrical tape is a good precaution to prevent accidental sparking fro the battery negative cable while it is disconnected from the ground screw.
4. Disconnect the blue clip [A] at the outside base of battery tray. Pull the rubber band
battery retainer [B] down and unhook it from the battery tray. Use an 8mm socket to remove the two bolts [C] and remove the battery tray retainer [D]. Pull the battery tray out one inch and remove the battery cover [E]. Pull back the red rubber insulator [F] and use a phillips head screwdriver to remove the positive battery cable [G] from the positive battery terminal. Pull the battery tray out completely. Remove the rubber band hold down from the tray and remove the battery.
Installation
5. Installation of the OEM battery is the reverse procedure. It’s always a good
idea to use some dialectric grease on the battery poles and cable connectors so that corrosion is prevented.
Shorai Battery 14A-BS12 Install
The Shorai lithium iron batteries have been out for a few years now. Some owners had problems with batteries that were from a certain lot that came out early in production. The defective batteries were replaced promptly as Shorai was contacted by the owners. The battery I purchased has run flawlessly for the past year. It was stored off of a charger in an unheated garage for one winter and the bike started after 3 months. Also the battery sat indoors for two months before I installed it and it started without an issue then as well.
The most important reason to own a Shorai is not the performance (although the performance is at least as good as lead acid batteries of comparable power). The reduction in weight is dramatic. Even if a Shorai battery of greater power is used, the weight is still far less than OEM batteries.
The Shorai LFX14A2-BS12 has identical specs to the OEM battery in the ZX-14. My experience so far has been that the Shorai 14Ah performs exactly as I remember the stock battery performing (before it finally died after 3.5 years). The Shorai 14 Ah is entirely adequate to start the bike in typical weather. It will do the job in the dead of winter after the bike sat for a couple months but it will crank more slowly just like the OEM battery did.
The Shorai 14A-BS12 has a much smaller battery case than the OEM battery and it will fall through the bottom of the OEM battery tray. Since a battery needs to be held stable inside the battery box, I decided to keep the light weight plastic OEM battery tray and mod it to hold the Shorai 14Ah. That procedure is detailed below.
As you will see, the Shorai 14A-BS12 needs to be installed with the positive pole inboard and the negative pole out. The only disadvantage with this is that the battery needs to be almost fully pulled out to remove the positive cable. However, the positive battery cable is designed for a much taller battery so having the extra distance to stretch actually works out fine.
This is a very good thread about Shorai batteries. It is long but it includes some great research, pics and video.
Tools:
5mm hex tool.
8mm socket
dialectric grease
1/4” plywood
pencil
Center punch
electric drill
1/8” drill bit
14” zip tie
silicone lubricant
6. Cut a piece of 1/4” plywood 3 5/16 inches high and 5 7/8 inches wide to fit the bottom of the battery tray. Use a pencil to mark a line 1 inch from the bottom edge and then make a mark for a drill hole 1 1/2 inches from the left and another 2 7/8 inches from the left.
7. Center punch the hole marks. Use an electric drill with an 1/8” drill bit to make a hole at each drill hole mark.
8. Place the plywood in the bottom of the OEM battery tray. The drilled holes should be closest to the back left of the motorcycle when the tray is installed.
The holes are positioned as shown so that the battery will be held deeper into the battery compartment, away from the door. This seems to work best for allowing the positive cable enough room to loop around so that its entire length is taken up without having to bend the cable a lot.
9. Place the Shorai 14A2-BS12 battery into the tray and thread a 14” zip tie through each hole. Wrap the zip ties under the battery tray and around the back of the battery. Slide the ends together and lock the zip ties so that they tightly hold the battery, tray and plywood together. The battery will be held in the front left corner of the battery tray.
10. Use a phillips screwdriver to connect the positive battery cable to the positive post which will be located toward the inside of the battery box, away from the door. Slide the red rubber insulator boot up and over the the connection at the battery pole. Leave the battery cover and rubber strap off. The cover is unnecessary as long as the red rubber cover remans on the positive pole of the battery. The battery is now held in the tray by the zip ties.
The Shorai 14Ah battery installed with cables shaped to accommodate the battery height and polarity. When installed, it will be necessary to bend the positive cable down somewhat but it will easily adjust for a taller battery again if necessary. The negative cable will also need to be bent so that it doubles back but it is not necessary to make any sharp bends or kinks in the cable. It will be easily readapted to an OEM battery.
Lithium iron batteries are not supposed to corrode but I noticed a yellow crust on my poles after some time. I apply dialelectric grease to the connectors and battery poles and I have not seen the crust return in 7 years of service.
11. Refer to the photo below as well as the pics in steps 2, 3, 4. Slide the tray back into the battery compartment with the two short pegs pointed out. Place the battery tray retainer over the pegs on the tray and fasten the tray in position using an 8mm socket to tighten the two bolts. Connect the blue clip on the battery tray retainer. Apply dialelectric grease to the bolt and contacts of the negative battery cable. Use an 8mm socket to connect the negative cable to its ground on the frame outside of the battery compartment. Apply silicone lubricant to the projection on the back of the battery door. Replace the battery door and fasten the bolt with a 5mm hex tool. Replace right Forman (See FAIRINGS REMOVAL, Formans).
Weight Loss
The OEM battery is 11 lbs, 12 oz
The Shorai battery is 24.70 ounces (1 lb, 8.7 oz)
The battery cover and strap that have been eliminated are an additional 3.70
ounces.
Total weight savings of 10 lb, 7 oz.
* Last updated by: Rook on 9/3/2017 @ 6:17 PM *
sreynolds
RE: Battery Removal and Shorai 14 Ah Install
05/17/12 5:49 PM
Wow thats too cool. Between Brocks or comparable system & the battery mod is 51 lb. Thats significate. Thanks for posting.
05/18/12 1:29 PM
sure.
madskillz
07/21/12 12:15 AM
Any issues at all with this battery I herd some fire rumors?
2008\2009 ZX14 Silver Bull
07/23/12 8:58 AM
I saw pics of a Ducati enveloped in a cloud of smoke. That was one of the old defective batteries that Shorai replaced. Don't know if they replace bikes.
No problems with fire or anything with mine. Far as I know, the Shorais are now all working great.
bigwilliezx
bigwilliezx's Gravatar
07/24/12 2:59 AM
+1
Life may begin at 30, but it doesn't get real interesting until about 150... Ride or die!
2010 SE(Black/Titanium) - PCV,Piper X Filter,Dual Rad Fans,Muzzy Rr Fndr elim,Pro Tek Frm Sldrs,PM Heathen Wheels,PM Chrome sprocket,Corbin Canyon Dual Sport seat,Brocks CT Duals,Shorai LFX18A1-BS12,CRG Roll-a-Click levers,Cox Radiator Guard, GP Thunder 8500k 65W Hi/Lo-Beam Xenon blbs,Engine Ice,Flush mount front turn signals,MRA Spoiler Screen,HeliBars 1" bar risers,Goodridge Stainless Steel Brake Lines (F/R) and a Powerbronze Hugger fender - More coming!
2009 ZX10R CBO,Saddleman Trk Seat,Piper X Filter,Cox Rad Guard,Shorai battery,CRG Levers,Galfer SS Lines,Driven SBOP,Yoshimura Frm Sldrs,Speedo Healer/X-TRE/17-44 Driven grs,Bazzaz ZFI-QS w/Map switch,MJS Perf Ceramic Coated Race header,Akra SS mid pipe/CF Evo Slip on,R@G Racing Case/Front Axle sliders,Rizoma Veloce L Mirrors,Hyperpro Steering Damper,MRA Spoiler Screen,Servo Elim,Evotech Exh Hanger,CF Rr Hugger(Ohlins,Marchesini,coming s
01/26/13 10:35 AM
From my 14's maintenance log:
04/11/11
Replaced battery
Bike would not start, instrument cluster flashed rapidly in time with ticking noise coming from instrument cluster and ECU. Battery was replaced with a Shorai Litheum battery LFX14A2-BS12
Now almost 3 years later. The Shorai (smaller than manufacturer recommends for my bike) started my bike 1 month ago in 45 degree F ambient temperature. The bike had sat with Shorai battery in it for a few weeks without any charger in a unheated garage. The bike required 3 attempts and it backfired 2 times during cranking. The second backfire was a pretty good one but the engine started. This is at 45K miles with original plugs still in and throttle bodies never synced.
I have used a Shorai charger for winter storage during each of the two winters that battery has been in the bike.
The specs provided by Shorai are identical to those of the OEM (Yuasa) battery. The Shorai performs very similar to the OEM battery to my recollection. The OEM battery lasted 3 years before it died with only a few warning signs. Hope the Shorai lives longer but if not, I will buy another because of the outstanding weight reduction.
luddy178
luddy178's Gravatar
02/21/13 8:30 PM
If you go with the LFX21A6 it is almost a exact match (2mm pad for hight) and the CCA is into the 300s and cranks with authority. I've been using it now for 4 months and loving every minute. Still has a great weight savings.
* Last updated by: luddy178 on 2/21/2013 @ 8:31 PM *
04/22/13 2:30 AM
Had no idea this product was out there!!! Thanks boyz!
04/22/13 12:44 PM
It is a little controvercial. I've had good luck. Not everyone else has. The battery I have is 14V which is a bit smaller than what others normally use for the 14 but it has worked good for me for over two years. Still seems good as new.
The Shoai battery maintainer is probably the key to longevity. Mine has been hooked up over winter storage two out of three winters now. Also used a lead acid maintainer (w/OUT desulphide capability!!!) on it. Seems to have done no harm.
* Last updated by: Rook on 4/22/2013 @ 12:47 PM *
CoolBrzBlu
CoolBrzBlu's Gravatar
07/12/16 8:22 PM
The newer Antigravity Batteries SC-1 is about 12 oz, and is small enough to be able to lay flat in the battery tray if notches are cut for the terminals. According to the bike it has more starting voltage than the stock battery.
07/12/16 10:31 PM
Antigravity has been out a while. Research the reliabilty. If it looks good, GO FOR IT! For now, my Shorai is not giving any signs of needing replacement.
CoolBrzBlu
07/13/16 9:46 PM
At least it saves some weight/space. It fits perfectly in the battery tray.
I just hope mine doesn't blow up on my trip this weekend.
* Last updated by: CoolBrzBlu on 7/13/2016 @ 9:48 PM *
07/13/16 11:05 PM
I love it! Good to know where battery technology is going. How does it crank compared to stock?
CoolBrzBlu
07/14/16 12:22 AM
Cranks great. According to the bike it has 13.4 volts compared to stock at 12.x. So far so good...
I used this battery on my zx10 before, but it didn't last that long. I think I discharged it too far the first time, and then bought a second one. The price isn't bad and its hard to beat such a small powerful battery, unless it burns/explodes.
07/14/16 8:49 AM
All you can do is google the most recent reports. If you se several that are recent, I guess you are reason for concern. If not, heck, there were reports of Shorais that caught fire when I put mine in but too many that were recent. That's a nice spacious battery box you have now.
12/29/16 4:02 PM
to me: check pics
WillsZX14R
WillsZX14R's Gravatar
03/22/17 11:06 AM
just bought a Yuasa...damn it;s heavy..got it on stand up. Current is still kicking.
03/22/17 3:51 PM
Just go with a Shorai. It will outlast a lead/acid battery and be a lot lighter.
GIXXERCON
GIXXERCON's Gravatar
03/29/17 11:21 AM
Factory battery in mine just died after 8 years. To be fair though- last time I started the bike was at the beginning of August before placing it in storage... Possibly could've gone longer had I pulled the battery and kept it on a trickle.
Dropped the battery at Advance Auto for a $20 store credit and went with another factory Yuasa from Amazon. Next battery will have to be Lithium if this one doesn't live up to my stocker's expectancy.
* Last updated by: GIXXERCON on 3/29/2017 @ 11:23 AM *
09 Candy Lime Green - Two Bros full M2 Black edition CF - PCV - Flies out - 17/45 gearing - Dunlop Q3s - DDM HIDs
03/29/17 3:35 PM
Eight years is the longest I've ever heard the stock battery lasting. My 08 busa still has its stock battery though so I think I got you beat. Believe it has much to do with limited use. that bike has only 11k miles.
04/12/17 12:09 PM
updated
