Thread: i need header install help
Created on: 02/04/11 05:21 PM
adamsgeneral
adamsgeneral's Gravatar
02/04/11 5:21 PM
ok everyone, just bought a yoshi 4-2-1 system. i cannot figure this out. i installed all the parts, looks great, fired it up, and wow! what a noise coming from the headers. it appears that the header is not seated to the engine, like it should. all the springs are on, is there a step im missing? is the only thing holding the headers on is the springs? that cant seem right, i can look where the header meets up with the engine, and i see a gap. any help would be just great. thanks- adam
2010 SE ZX14.
scottjkyl
scottjkyl's Gravatar
RE: i need header install help
02/04/11 6:33 PM
did you seal the header pipes going into the flanges with hi temp copper sealant?
adamsgeneral
02/04/11 7:22 PM
no, but i can see a gap between the tubes, and the engine. how do i make that gap go away?
2010 SE ZX14.
02/04/11 10:39 PM
The header pipes/exhaust manifold/gasket isn't on there?How can that be?It should be shouldn't it?Something to tighten down the header pipes to the block?Rings or something?Mine has two small bolts on there(each head pipe)...you're saying you don't have any fasteners except springs?Hmmmmm....doesn't sound right to me.They should mate up onto the head there,yes?Flush with the block?Or slightly going into the ports?Something's not okay.Where are the stock tightening/fastening rings?(unless I've got this all wrong here).
* Last updated by: blue07 on 2/4/2011 @ 10:41 PM *
adamsgeneral
02/05/11 9:40 AM
in the yoshi instructions, it says the stock rings are not used. so i dunno. i may try to see what else i can come up with
2010 SE ZX14.
02/05/11 1:06 PM
Keep checking around for info.
Kruz had a heck of a time with his yoshi headers fitting his CBRHonda. He torqued the F%%K out of them and never got them to seat right. He ended up throwing them in the dumpster. No damage was done but he went to Akra after that on all his bikes.
--Not saying there should be any problem with the 14 and Yoshi full systems--never heard that before---but check around. Hope you get it on there right.
adamsgeneral
02/05/11 2:23 PM
hub, you got it. that is what i did wrong. the collars are how they are supposed to be, and the bike runs great. thanks for the help
2010 SE ZX14.
