Ok hers's an update on rear sets. NOTE: As delivered manufacture states the set up is for standard shift..
I never tried install as standard shift, as i wanted the reverse shift pattern or GP shift as others call it and will be installing an Anntori quick shifter at alater date..
Installation of rear sets was pretty strait forward. Took a while to get shift rod set up to where i'd like to get shift lever to be.
Note: Rear sets will not work for reverse shift as delivered. Modifications will be needed!
1. Shift adapater when reversed will touch or bind on lower plastics.
2. May also have interference with kickstand. I have an adjustable one. Stock one may not be an issue.
3.Shift rod is at a wierd 45 degree angle. Will interfere with shift lever as it sits on top of it no cleaance for lever when shifting down.
Here is what I did to get them to work to my likeing. You may have to modify this for your set up. Also I wear a size 13 inch shoe/boot so i need exta space for shift/brake pedals for better feel.
1. Setup comes with 2 small brass spaceces on bolts for shift rod. I uesed those when attaching shift rod to shift lever.
2.You will need 2 1/2 inch spacers attached between frame mount bracket and shift lever mount. This is to get the shift rod at a straigt angel. I used the longer bolts that come with the kit as i used stock bolts to mount frame bracket.
3. you will also need to use 2-4 1/2 inch washers to foot peg. Make sure that the washer that comes with the foot peg setup is used next to shift peg. It has and indent that is needed so that foot peg bering doesn't bind.
3. You may also need a longer bolt for the foot peg to compensate for extra space taken up by washer.
4. I used red loctite on all bolt locations. If not they will vibrate loose at some point.
5. I also used the 1/2 inch spacers on the brake side to even things out.
6. Used a 1/2 inch spacer and longer bolt on lower plastic bolt mount to get clerance of shift rod on plastices. Didn't want to cut a notch in plastics for shift rod.
Hope this helps some one.
Pictures are of final set up. I did a 40 mile test run and it all works so far. I will update once i get some more miles in. whish i had taken better pictures of install. I can do a more detailed install at a later date if any one is interested.
SHIFT SIDE:
BRAKE SIDE:
Luvin My ZX14R'S.
