Hi all,
about to remove PAIR hoses etc. from ZZR1400 2012.
When I take off the air switching valve do I need to replace it with a 22 OHM resistor.
Thanks.
Created on: 02/07/15 12:20 PM
kwakamax
untamed
RE: PAIR Qestion
02/08/15 7:07 AM
I asked how to disable the pair set up on a ZZR1400 on another thread because I ket getting an error light coming on. Hub's answer was it doesn't matter what the resistance is. Havent tried it yet, but got a few different resistance resistors just in case. If you don't mind let me know if something doesn't work or what works best.
maverick1441
RE: PAIR Qestion
02/08/15 9:50 AM
Theory goes like this with a 2 wire kind of move.
1 = On
0 = Off
Flip = Flow
Flop = No Flow
Unplugged = Not a complete circuit.
Unplugged = Idiot light comes on and says are we plugged in?
Plugged In = I want to be connected and I don't care about values, complete me as a connection.
Any Value = I completed a circuit and it made the flip do its flop was flip the light offandango.
However, a 3-wire connection ties in with someone else so someone is watching the values, not a simple connect to complete a circuit by its own [2-wires] meaning.
TRE Me = I could if only you were one value or an on to off kind of move is plug 2 wires together to complete a circuit.
Tre Me 7 times = The values out the wires is the gear position knowing what number to send in the window.
Flip Me = Take any valued resistor is now the same as saying I am disconnected/value(s) out of range/short to ground.
Flop Me = Behindoor #2 is 'values out of range' x's 7 (1N23456) is the answer. It is connected so that is not it. It is not short to ground or the fuse would blow. There is only one thing left on the basic find the fault root of the problem.
Diagnostic solved.
Use any resistor for 2-wires to flip a flop on and off goes the light.
Use any resistor for 3-wires to set a code, because no matter the resistor, where are the other 6 you can't address out the one wire? So you can't and that says it does not matter here as well. You set the code and that was the point is kept the circuit in its loop or complete that circuit...
WATThell did Hub just say?
maverick1441
RE: PAIR Qestion
02/08/15 1:09 PM
I am so locked in the loop, the handcuff, the can't get out of jail card, for I have no clue how many times I repeated the same combinations and this has been year after year the same exact info regurgitated.
How come all of a sudden it makes sense now?
maverick1441
