LOL I think it's the other way around, they used to flash fueling and everything but in the last couple years, they've been recommending a PCV along with the flash even if they already flash the fueling. Personally, I think flashing without at least offering to flash fueling is a rip off. Why make a poor guy go buy a PC5 if you flashed his ECU? I think a PC5 will give you a little better fueling but I don't think everyone really needs that.
You can get everything but fueling from Schnitz for $70.
The only reason I can think of why you wouldn't want a good fuel map flashed is that you can no longer compare your PC5 edits to a stock map and you cannot compare those edits to stock performance on your own bike anymore and you cannot run a different map that was created for stock fueling. You would have to compare/adjust everything to Ivan fueling. I'm sure Ivan fueling is the cats ass but it could get awfully damned confusing if you wanted to play around with self tuning and definitelt if you wanted to use somone else's map. This is why me, the guy with all the self tuning accoutrements who likes to self tune probably would prefer to not have timing or fueling flashed until I am damned well certain it is as perfect as it can be for my bike (maybe---who knows---you get engine work done, turbo, NOS---no longer perfect).
If you don't want to hassle with self tuning or pay extra for the equipment, I think a flasher should offer to give you all of his ECU work. If you want to do a PC5+ignition, the flasher should give you his DJ fuel and ignition maps free with a flash.
On the other hand, the stock fueling and ignition tables are much more intricate than a DJ fuel table. I can see how you could get smoother results from a map that is not perfect for your bike than you would with a DJ map that is spot on. Possible. DJ electronics do automatically make calculations for throttle position and RPM where those parameters are "between" the values that are established for the cells a DJ map has. A flash has all the same cells as stock of course.
SO it's up to you how far you want to evolve in this game but the end of it is that you have a flash, a PC5+ignition, and finally, you get your own flashing software. It all depends on how depp a money pit you want to dig yourself and how much really think you can really gain through ever finer tuning.
* Last updated by: Rook on 7/12/2017 @ 3:43 PM *
