Thread: Setting the Clock Time
Created on: 09/09/10 09:00 AM
bgordon
Forum Administrator
bgordon's Gravatar
Grand Junction, CO
09/09/10 9:00 AM
Someone asked for instructions for setting the time in the ZX-14 clock, and the instructions in the manual didn't seem too clear, so I went through the process to document it here. It involves the use of the two buttons in the middle of the "Meter Instruments", between the speedometer and that tachometer.
The call the top button "Mode" and the bottom button "Reset", but I'll just use "top" and "bottom" here.
To set the clock time:
  1. Press and hold both buttons for 2 seconds, until you see the language selection screen
  2. Press the top button to select English
  3. Press the top button 3 times on the next screen to get to "Clock"
  4. Press and hold the top button for 2 seconds until the time starts flashing
  5. Press the bottom button once, so the hour setting will flash by itself
  6. Press the top button repeatedly to advance the hour setting to the proper hour
  7. Press the bottom button once, so that the minutes setting will flash by itself
  8. Press the top button repeatedly to advance the minutes setting to the proper time
  9. Press the bottom button to store the time setting
  10. Press and hold both buttons for 2 seconds to return to your normal display
-bg
