All I can do is talk about a few bikes that came thru my hands recently. I got one running after 29yrs sitting. 20k miles on it, Leak was 4% equally at each corner. Ran Motul and used a motul sticker when changing oils. These are Honda's offer to the police, and have a reputation of lasting for over 200k miles.
Now I'll bring this up and can't say that it is fact, but more junk science: but you tell me. Both bikes lived in the same county, give a take a few counties either way. So one was a water cooled V-4 carbureted, the other was another Honda sitting 10yrs, with coolant and FI. The FI bike was 100% leak at both cylinders of this V-Twin.
The V-4's oil pan was dropped and inspected. Never saw such a clean pan, not a spec of any break-in debris whatsoever. And double the years sitting, with I believe there being zip about any ring seized in the grooves. I have the leak video of all equal leakdown numbers.
For the twin's leak, found a frozen valve open is one, found the rings locked at the rear, and with the front having the open intake, I still soaked the cylinders down with one brand after another to soften the rings up. Leaked it again, maybe 40% at the rear, forgot the other, or thinking 20% pops in the head. Oh, and the original 54 miles on the speedo, with the OEM tires still with the rubber stubs.
Can I associate both the clean pan and the unstuck rings to Motul? Well, the mileage reputation alone is any oil will do. The other is ring seizure to me says larger rings as opposed to, update the rings of today; are a lot thinner, and say the proportion to ring growth to ring groove gap still stuck the rings and valve with that unknown oil?
I sort of mess with a mixing of oils to stop any oil thread saying who has what to throw in. But I did buy Motul and added that along with 50w and whatever else is around to top it off.
So lets say what it's not:
Can't be the heat treating. It's all about thermodynamics on that stick and no way can I think it's 1 bump out of how many being treated at the same time and that production run?
Can't be the oil if the bumps look shiny and worn but still look new, and still within spec.
Can't be any other answer but CB450 steel to steal Blue.
