Looking for a tre to hold the flies open
* Last updated by: riggsracin on 8/5/2012 @ 5:57 PM *
Created on: 08/05/12 05:56 PM
riggsracin
RE: looking ro used tre
08/06/12 5:31 AM
TRE's don't hold the flies open, they fool the ECU into thinking the transmission's always in 6th gear, which eliminates the timing retard in the first three gears. TRE-timing retard eliminator.
riggsracin
08/06/12 12:52 PM
The easy remedy for that is to remove the secondaries. Then they open when you twist the wick. They are controlled by the ECU, as is the timing.
