Just got a set of Shogun sliders. Do I need to somehow support the bottom of the engine when removing the bolt to install the slider? If so, which portion of the bottom area should I set a jack?
Created on: 03/06/16 08:49 AM
OldMan
Shogun Sliders
03/06/16 8:49 AM
RE: Shogun Sliders
03/06/16 9:06 AM
Not necessary but not a bad idea either. I did not support the engine when I installed mine and I just recently removed the sliders and reinstalled the factory bolts. Just make sure to torque to spec with some red lock-tite.
RE: Shogun Sliders
03/06/16 10:47 AM
If this is like the sliders I put on my Gen1, you can just do one side at a time. one front engine mount bolt will hold it while you install a slider to the other side. I have only used blue loktite. My concern is removing a red loktited bolt that was torqued might be pretty hard.
OldMan
RE: Shogun Sliders
03/06/16 11:54 AM
Hi Cruderudy, Rook,
Thank you for your feedback. I believe torque is 44ft-lb for the front engine mount bolt. Do I really need to use Locktite?
OldMan
RE: Shogun Sliders
03/06/16 3:59 PM
Just installed sliders. I used the blue locktitie. Sliders look good. Hope they remain as just part of the body design
RE: Shogun Sliders
03/06/16 7:07 PM
* Last updated by: Rook on 3/6/2016 @ 7:08 PM *
RE: Shogun Sliders
03/06/16 7:33 PM
...reminds me...there was a thread about a year ago where a guy had stripped one of these engine mounts. He got a longer bolt and stuck a nut with a lock washer on the inside and apparently it worked.
