I have lost the power wheelie in 2nd gear. Use to go WOT around 4k and would be pulling the front by 6k to 7k now nothing. Any ideas
2013 ZX14R AH2 with Cblast flash,yoshi fender eliminator, stompgrip tank pads, ASV levers.
Created on: 04/18/15 07:17 AM
SlowBen
Nastynotch
RE: Lose of power?
04/18/15 8:40 AM
Hmm how many miles ? if its not the tires, somethings wrong, mine comes right up in second, especially with
the Cblast flash !!! i accidentally did it right in front of a cop one time, when I was getting on the
freeway !! LOL !!
maverick1441
SlowBen
RE: Lose of power?
04/18/15 9:19 AM
The has 1800 mi. The rear tier is starting to flatten out a little bit come up in first noproblem. I don't think the clutch is slipping think being the main word there. TC is off. Chain is lubed up. The motor seems to run fine. Breaks are not dragging. I'm lost here man.
pegscraper
RE: Lose of power?
04/18/15 10:55 AM
To check for clutch slippage choose a private road or airstrip get in 4th or 5th around 7-7500 rpm where max torque is and accelerate hard. This is where the clutch is under real pressure, more so than trying to lift the front in 2nd and any slippage should be more obvious. If the rear tyre has gone off I would expect it to lift the front easier in 1st than 2nd. JMO
Nastynotch
RE: Lose of power?
04/18/15 11:07 AM
zx14rider345
darryle
SlowBen
RE: Lose of power?
04/18/15 2:34 PM
Check compression with only 1800mi. Could plugs be bad already. And throttle body out of sync. If any of these is the problem it's going back to the dealer.
skewedTotheLeft
RE: Lose of power?
04/18/15 2:47 PM
My bike will power wheelie in second even with the swing-arms extended 4.75 inches and lowered 1.25 inches. Of course for traction I use the very sticky Shinko Hookup drag radial on the rear.
* Last updated by: skewedTotheLeft on 4/18/2015 @ 2:48 PM *
maverick1441
runnerhiker
dehaile
Nightmare
RE: Lose of power?
04/18/15 9:03 PM
1,800 miles is probably the best time to check your compression and make sure you write these numbers down (front of your service manual is a good spot). Even if the numbers look good, now you have a point of reference for future compression tests. If there's a big difference between cylinders you may have uncovered a major issue while the bike is still under warranty. Worst case you spent an hour of your day and recorded some great info.
RE: Lose of power?
04/18/15 10:25 PM
The motor seems to run fine. I'm lost here man.
* Last updated by: Hub on 4/18/2015 @ 10:25 PM *
SlowBen
RE: Lose of power?
04/19/15 5:53 AM
Hub, you are right I didn't stay under 4k but I also didn't beat the s#it out of it. Your advice is well heard and I will check compression. I will be looking at everything very closely tomorrow. Here is a pic of my tire.
SlowBen
RE: Lose of power?
04/19/15 7:52 AM
Vic, I will work on that for you sir. Haven't had to many warm days that I didn't have to go to work. That's my excuse anyways lol
RE: Lose of power?
04/19/15 10:07 AM
I think I found your problem, it's the Metzlers !!!! haha ! seriously though, one of the
best things I did, was get rid of the metzlers and put on PR4's just sayin .....
SlowBen
RE: Lose of power?
04/20/15 1:14 PM
Well my power is back. Took it out and tried some the things you all recommend. My clutch wasn't slipping but what I found out with some help of Cblast is that my plugs were fouled out from me riding back and forth to work. I have been riding to work as much as possible witch is 25mi one way and it is highway that is cop central. Needless to say I putt the hole way 60mph. Got out to day and rode it hard and it came back to life 2nd gear wheeling back in session and the lovely 3rd gear lift. That's for the help guys.
SlowBen
RE: Lose of power?
04/20/15 1:19 PM
Vic I work on that a little to day for you. It's been raining just starting to dry up. And carabuser I plan on getting the PR4 when These are done.
