Thread: AFR, PSi and cruising...
Created on: 01/06/10 09:47 AM
JDC
JDC's Gravatar
AFR, PSI and cruising...
01/06/10 9:47 AM
I have been playing with, have been since the Bazzaz gadget was installed, my 'cruise' AFR to better MPG while cruising - speeds up to about 90 MPH. Initially I had the AFR for 10% and lower and RPM below 4500K to 13.7 (cruising up to 90 MPH). I am going to change that to 14.7 I think, increase the TP range from 0% to 15%, and see how that goes.
Anyone have any thoughts on having the AFR at 14.7 for 'cruising', TP 15% and lower, RPM up to 4500, where PSI is 1 LB or less? Timing is -6 static with Muzzy plate. Seems safe to me...
* Last updated by: JDC on 1/6/2010 @ 9:50 AM *
