Hey guys just bought my 06 zx14 a couple weeks ago that has a full exhaust. I figured I needed a power commander so I bought a new pc5. I had decided to remove my secondary flies so when I was tearing the bike apart I fould it had a power commander 3 on it already. seller of the new one I bought won't take returns so I just put the new one on. but before removing the pc3 I uploaded a map for the full exhaust with secondary flies removed. so that is the current map it has installed. From research it will fit the 06 07 and possibly 08. The part number is 224-410 and below that number is 224-411. Works perfect just don't need it since i can't send my new one back to the ebay seller. i don't have the original usb cable to connect the pc3 to the laptop but I used the usb cable from my gopro camera. If you need another map I can tell ya how to do it or I can load one in for you. I just have to connect it to my bike so it will power up. I guess there is supposed to be some small 9volt battery adapter you can use to power it up so you can change maps while the pc3 is off the bike but it never came with the bike so I just changed the map while it was hooked up to my bike so the 9volt adapter is not needed. Would like $160 shipped and I can help you over the phone install it or load maps if ya need.. Any questions please ask or pm me and I can give you my cell number. Thanks
[img][/img]
