does anyone here own a 08 and have you ever had any problems out of it.?
yes, 28,000 miles and the only trouble is a leak from the top engine. Very slow. Never enough to deposit a single drop on the floor, even after sitting 4 months in winter. The leak is almost definitely a valve cover gasket leak which is a common problem. We throw a washer under the hed of each valve cover bolt and retorque. The threads are designed to be exactly as deep as the threads on the screws but over time----I guess the gasket flattens or something. No way to tighten down more so the washer trick seems a common fix. I plan to just replace the gasket.
Cons
1. valve cover leak -not too big a deal
2. rod bearing spins serious sh!t byre-bye motor, happens to a few, I have heard of ~6 owners on this forum since 08 and seems like one rod bearing fail was on an 08.
3. cam chain rattle--no problem just a PITA to listen to.
4. Gas mileage is no better than a small 4 cyl toyota. lot faster though.
5. Suspension could be a lot stiffer for the bigger guys. Might be something you wil want to upgrade if you are 250+ or carry passenger.
6. Loud clunk into 1st from N. No harm, just another PITA to listen to.
7. Top engine is not the easiest to get your hands on. Plugs are hard to get to.
8. Seat cowl rattles. IDK, I seem tio be the only person wha has complained of this since 2008.
9. Side stand is kind of iffy. Be very careful and be certain it is down all the way dont park on an ANY incline without bike in gear resting on trans.
PROs
1. Looks great. Best looking bike made to this day, IMO. Still love to look at the bike.
2. gobs of power. Super smooth 100mph is like nothing.
3. Superb brakes
4. Handles very well for a large bike.
5. Best bike for just about all kinds of riding the average guy is going to do. Twisties, commuting, touring, speed runs Drag race, LSR even road course track, it will hold it's own.
6. about the only sport bike you will want to carry a passenger on.
