Danno your parts list sound correct. Make sure the side racks and top rack are SW-Motech, not Givi.
While you are ordering at Twisted Throttle, buy the Euro tail piece with the notch in it (beats trying to cut the notch the right size), too. You can get it in your bike's color or close enough.
Also, when you get the side racks, order the locks so nobody can pop the side racks and take them and the bags with just a screw driver.
Depending on what top-case you get, it may have lights or not, so you may want to wire it to your brake light. I mounted the included quick disconnect on the new tail piece, under the alu-rack, so when I put the plastic adapter plate on, I plug the coax connector in under the alu-rack, and then you have brake lights on the top-case.
If you get around to it, get the AdMore LED light kits for both the top case and the v35 side cases. The wiring is a bit of a pain, but doesn't take all that long. The light kit for the v35 side cases does running lights, turn signals, and brake lights. Really increases your visibility from behind.
And by all means, order the key/tumbler kit, so all three cases are the same key. Monokey rocks, but you have to change the tumblers to get side cases same as top case.
* Last updated by: privateer on 1/25/2012 @ 10:33 PM *
I already have the topcase, an E41(I think, whatever Givi made for Kawasaki ZZR 1200 sidebags) so I don't know if it can be keyed like the V35s. I will also need the adaptor plate for the Alu-Rack since the freebie E41 didn't come with one.
Don't know if the light kit is worth the trouble since i rarely ride at night anymore unless I get caught out. But I'm all for anything that makes a bike more visible.
I will definitely check into the rack locks since I know how easy they are to pop off.
Also, I have a spare tailpiece that's already been notched somewhat, so no great loss if I booger it up on the first flop.
* Last updated by: Danno on 1/26/2012 @ 1:45 PM *
