Thread: handle risers
Created on: 03/17/09 06:52 PM
jayzx14
handle risers
03/17/09 6:52 PM
well,being in wisconsin, i forgot that last fall i wanted to raise the bars a little...what are u guys doing?? 3/4"-1-1/4"? and where is the place to get them? thanks in advance
dhsec5
dhsec5's Gravatar
Fort Washington MD.
RE: handle risers
03/18/09 1:12 AM
I used Heli. Easy install- http://www.helibars.com/proddetail.php?prod=HC2614
BLACK 06 ZX-14 FLIES OUT,PC III,TWO BROTHERS SLIP-ONS,COBIN SEAT,CHROMED FOOT PEG BRACKETS,CHROMED RIMS,REAR TIRE HUGGER,CERAMIC COATED HEADERS(NOT SHOWN IN PICTURE),GARMIN ZUMO550,SCORPION ALARM,139 db HORN, DB WINDSCREEN, HELI BAR RISERS,FENDER ELIMINATOR
jayzx14
RE: handle risers
03/18/09 6:24 AM
how tall did you go? I am 6'0..so I am not sure what height would be good.
dhsec5
dhsec5's Gravatar
Fort Washington MD.
RE: handle risers
03/18/09 10:23 AM
The risers are 3//4". The bars can be turned all the way to each side and are still clear or the fairing. I am 6'0 also.
gumbybob
gumbybob's Gravatar
RE: handle risers
03/19/09 4:12 AM
I put the Genmars on.
One inch rise. No problems. Ten minute install, total.
Hoses barely long enough, but they fit.
Brake reservoir just barely touches the inside fairing when bars are turned all the way to the left, but it's not a problem. Other 14,s don't touch at all.
JayFell
JayFell's Gravatar
RE: handle risers
03/19/09 4:54 AM
MHO: Heli's rule. Takes just a few minutes. I'm 6'3" with shortish legs and a long upper body so I definitely feel out in the wind and above the eddy-bubble a bit more but my wrists are happy. Maybe a Puig is next. Seems to make the perfect machine that much better.
notfirstbutnext
notfirstbutnext's Gravatar
RE: handle risers
03/19/09 10:33 PM
Heli risers make a big difference. I didn't think 3/4 of an inch would change much but it did. Very glad I performed this mod. Huge difference in wrist comfort. I am 6' 210.
zx142008
zx142008's Gravatar
Melbourne Australia
RE: handle risers
03/24/09 12:16 AM
Hey jay
Heli risers are the way 2 go i've fitted them to my 08-14 and they are just GREAT 3/4" higher made the world a greater place. I've had problems with my shoulder but no worry's now on my pride and joy...
ZX142008................................................................................................................
racertex
racertex's Gravatar
RE: handle risers
03/24/09 6:24 AM
Hello, I've got a set of Heli bar risers that were on my '08 14. They worked great, but I lost alot of weight and went back to the stock location. I'll sell them for $50 if you want them. If interested, I'll be glad to snap a couple of pics of them.
Happy Riding!
2008 ZX-14
Yoshi 4-1
PCIII w/custom map
Speedo Healer
hoopie
RE: handle risers
03/24/09 7:31 AM
Plus 3 for the heli risers. Easy install and makes a big difference in comfort. Im 6ft 215.
imrubicon
imrubicon's Gravatar
RE: handle risers
03/24/09 9:40 PM
L liked my raisers so much I changed them in the parking lot while doing the trade .
Made a big differnce to me
Lost in TX and I dont want to be found ,
2012Yamaha Tenere 1200 for really wandering off the beaten path
2005 GL1800 Sold to another to enjoy
2006 ST1300 Gone but not forgotten
2009 ZX14 Also gone and will be replaced someday
some of the best of both worlds
Rasher
Rasher's Gravatar
RE: handle risers
04/04/09 3:31 AM
Helibars - spot on, 20mm dont sound much, but makes a big difference if you get stuck in slow traffic or on a long days riding.
Flies Out \ PC3 \ Autocom \ Kwak Tall Screen \ Helibars \ Kawasaki Rack \ Givi Panniers and Top box (Ugh!) - Quick Detach :-) \ Tank Bag with Power - Magic! \ Novus Rider GPS (Camera Warning System)
chef
chef's Gravatar
RE: handle risers
04/05/09 1:14 PM
RACERTEX.
if the risers are still for sale, please pm me.
im not saying im the best, but im in the top 1.
privateer's Gravatar
RE: handle risers
04/05/09 7:23 PM
I've tried both Heli and Genmar. Have Genmar on now.
Both are essentially the same in terms of quality and fit. The Genmar give a bit more rise and kickback.
Living the Gypsy Life
RE: handle risers
04/05/09 8:22 PM
You can go with Helis AND Genmars-they'll fit on there together-just need 3" Allen bolts.I had both-worked very well for a time.
* Last updated by: blue07 on 4/28/2009 @ 11:00 PM *
RE: handle risers
04/06/09 4:57 AM
You can go with Helis AND Genmars-they'll fit on there together-just need 4" Allen bolts.I had both-worked very well for a time.
Blue, can you explain how to do that? With just the Genmars in, the reservoir makes contact (barely) with the inside of the windscreen frame at left lock. If you raised the clipons another 3/4" (Helis) you could not turn lock to lock, and in fact, could not remove the key from the ignition then.
At least, on my 08.
RE: handle risers
04/06/09 11:31 AM
You need to readjust the levers-dip the reservoirs just enough to clear the fairing.It still may lightly rub at full turn-you can also back that windscreen screw out just a bit,enough to let it clear.Mine worked okay-it MAY have rubbed ever so slightly-but nothing to worry about.(how often do you go full left or right?)Right?Never had trouble locking the steering.The fitment is in the brake lever perch angle.That's the key there.Get that right and it'll fit okay.Plus you can slightly bend the reservoir clamp,just enough to customize the fit.Be careful you don't just grab the plastic reservoir and yank it-the bolt fitting can crack(from bending the PLASTIC).You have to bend the bracket.(slightly).(don't use the reservoir to bend the bracket!)When you're done adjusting-you DON'T want the reservoir feed hole going "uphill".It should be level with the ground.(on both).
* Last updated by: blue07 on 4/6/2009 @ 11:42 AM *
markkat
RE: handle risers
04/28/09 10:44 PM
Blue07...Which did you put on first, the helis and then the genmars on top? Or do you think that the order matters? Thanks for your reply
RE: handle risers
04/28/09 11:02 PM
Yep.Helis,then Genmars.
ArkNinjaZX9
ArkNinjaZX9's Gravatar
RE: handle risers
05/07/09 7:35 PM
did you extend the brake line ? I've heard you need a longer brake line...thanks in advance
Always do right. This will gratify some people and astonish the rest.
Mark Twain
RE: handle risers
05/07/09 7:41 PM
Hello ARKNINJA-You will need to loosen your brake perch clamps,adjust the perch(for more slack)and re-route your brake line going from lever to junction at the lower fork plate.It needs to come over approx. 2 inches to the right-which can be done by fashioning a bracket,and reattaching to the fork plate mount.Easy deal.
ArkNinjaZX9
RE: handle risers
05/07/09 7:56 PM
Thanks Blue....now i need another set of risers and some long bolts...3 or 4 inch ?
Mark Twain
RE: handle risers
05/07/09 10:04 PM
You're using both,Genmars and Helis,right? You need four 3" allen bolts for your install.Have fun!!
jessejames4
jessejames4's Gravatar
Fairfield County, Connecticut
RE: handle risers
05/26/09 11:06 PM
I'm 6' as well, with real long legs. I do have the Genmars which adds an inch, but I still need to lower the seat and get lower footpegs so I don't feel so scrunched up. I've got the rear adjustable lowering links to install to bring the rear down an inch. Also will drop the nose an inch to dial everything in.
Jesse
97 zx11
06 zx14
* Last updated by: jessejames4 on 5/26/2009 @ 11:07 PM *
Jesse 06 zx14 stolen back in 2019 97 zx11
Nightmare
Nightmare's Gravatar
RE: handle risers
05/27/09 10:04 AM
Their specs say a 3/8" rear offset... not really sure what they are referring to (moving the clips back towards the rider?)
Has anyone heard of a similar product to this that you can also change the angle that the bars sit? I'd like to try a flatter angle as it seems that's how my hands natually sit on the bike.
