Ok, the gains aren't as big as I thought they would be and there is no deceleration popping removal on 06-07 generation with the flash. Since the fuel tables aren't messed with no tune is needed after the flash.
Turn around time is 3 days plus shipping back and forth.
Like SparkyG mentioned the extra 500 RPM would allow for some breathing room, especially if I initiate gearing change at 10,500 RPM. The top speed removal is also a good selling point for me! I'm going to be anal and get a custom tune on the bike. If I can milk 3-5 hp it'll be worth it in my opinion. Also, I will be able to tell where peak power is exactly, which is probably going to be pass 10,500 RPM. Next time, I'm doing upgrades or maintenance on the bike, I will probably send my ECU in.
I wasn't able to upload the graph they sent me but I saw a 2hp advantage from 5200 RPM which remains constant until redline.
Max HP: 193.61 Max Tq: 97.99 (with reflash)
Compared to
Max HP: 191.15 Max Tq: 96.75
Mods were: o-ring less chain, Factory Pro Short Stacks, CT-Single and probably 0 weigh oil.
Like I said power gains are minimal, and one could argue that the gains came from the velocity stacks. The extra 500RPM and the top speed removal are undeniable though. As far are bolt on mods go, I'm already maxed out. So I'm not surprised that 1 additional HP is going to cost me $100. The only things I have left are: Wheels, Gearing (maybe) Custom tune, Velocity Stacks and ECU flash
* Last updated by: dragking on 1/8/2013 @ 11:48 AM *
