Thread: Mobil 1
Created on: 07/31/10 12:33 AM
Mobil 1
07/31/10 12:33 AM
Howdy all.Lots of 14 owners are using Mobil 1.Can anyone tell me any particular "whys".I mean...just cause someone recommended it?Or are there concrete things about it that can be shown in the real world.
wienerwater
wienerwater's Gravatar
RE: Mobil 1
07/31/10 1:17 AM
Mobil 1 is a top notch, leading synthetic and haven't had a bad history of false claims, such as Castrol had a few years back.Castrol is up to date now, but have never been let down with Mobil products of any sort.
scottjkyl
scottjkyl's Gravatar
RE: Mobil 1
07/31/10 6:18 AM
blue just sent out a sample of mobil1 to blackstone ill post the results when i get them. Ive never had a problem with it but this time i used kawi synthetic
heathun
heathun's Gravatar
RE: Mobil 1
07/31/10 1:39 PM
Blue I started using mobile1 some time ago when I had seen an oil test. They tested automobile oils against motorcycle specific oils. Out of all the oils tested mobile1 was the only oil to retain over 90% (98%) of it's original weight after high heat testing. Mobile1 was also more shear resistant.
What I personally have found out is that 1. I don't have to add oil in between changes and 2. At 3000 miles the oil looks the same coming out as going in.
Currently I'm giving shell rotella synthetic and am pretty pleased.
scottjkyl
RE: Mobil 1
08/04/10 8:30 PM
after 2100mi mobil 1 started losing viscosity
heathun
heathun's Gravatar
RE: Mobil 1
08/04/10 9:49 PM
Not surprising. I've always heard that 10-40 shears to a 30 weight rather quickly.
