I brought home a new Toyota Tacoma that has tire pressure monitoring sensors. When I checked the Taco's tire pressure with the same electronic gage I check the bike tire pressure with, the knuckleheads at the stealership had all the tire between 45 and 50 psi. Spec on the door is 30 psi all around. So I let out air pressure until the digital gage read 30 psi - much nicer ride.
I dug into the manual and found how to select the TPMS mode display and it showed all tires read 33 psi - cold. WTF. SO I dug out two different mechanical tire pressure gages and rechecked all 4 tires again with both mechanical gages and the digital display gage. All tires are sat overnight cold and all of my gages read 33 psi and the Taco's TPMS display all shows all tires are 30 psi.
Not a big deal for the Taco but it sure got me wondering about the bike tire pressures. I recently watched a Dave Moss tire pressure YouTube vid and his process is to set the cold pressure to whatever PSI will raise the hot- after 45 min of normal fun riding, pressure 3 psi.
I'm now more confused than usual. With my digital gage, per DM technique (I'm betting HUB will disagree with Moss but hopefully he will engage here) my tires are set at 37 psi which raises to 40 psi after 30 min of twisty mountain roads. But based on what the Taco TPMS data shows I may be actually setting the initial bike tire PSI at 34 ??? high for the track but low for the street.
I dont have a way to calibrate anything, just a bunch of tire pressure sensors that are different. I understand the technology in the TPMS and kinda think I should trust a new tire pressure sensor vs. gages in my tool box.
Anyone have any knowledge on calibrating a gage or two?
Confused Rudy
