Thread: How to set clock?
Created on: 11/15/16 05:19 PM
Nastynotch
Nastynotch's Gravatar
How to set clock?
11/15/16 5:19 PM
Ok guys first off, I've been able to set the clock before, but cant for the life of me get the settings screen to pull up again. Whats the procedure? Thanks in advance.
2013 ZX-14R SE
2 Wheel dyno works flash
Muzzys black stainless slips
V1 custom mounted
Zero Gravity DB screen
Yoshimura fender eliminator
Black powder coated wheels
bfg9000
bfg9000's Gravatar
Cebu City, Philippines
RE: How to set clock?
11/15/16 5:30 PM
Press and hold down SEL button for 2 seconds.
Use the up/down buttons to get to the CLOCK setting.
Press SEL, hour display blinks, use up/down to set hour.
Press SEL again, minute display blinks, use up/down to set minute.
Press SEL again, display stops blinking, clock starts working again.
2013 Metallic Midnight Sapphire Blue ZX-14R + Brocks Alien Head 2 Full System | Spiegler Stainless Steel Braided Brake+Clutch Lines | ZG DB Windscreen | TBR JuiceBox Pro | Arashi Rearsets | BMC Street Air Filter | DME High Pressure Oil Relief Valve | Muzzys Oil Pump Cover | APE Flat Oil Drain Plug | FLO Reusable Oil Filter | Cox Racing Radiator Guard | GPR V4 Steering Stabilizer | CREE XHP-50 LED Headlights | LED Turn Signal Lights | Smoked LED Taillight | Targa Fender Eliminator | Tapemaster Strobed Reflective Rim Stripes | Ballistic Performance EVO3 Lithium-Ion Battery | Pirelli Diablo Rosso III tires
Nastynotch
11/15/16 5:41 PM
I've tried that procedure countless times with the key on, key off, and holding the button down while turning the key to the on position. Nothing I'm doing works.
2013 ZX-14R SE
V1 custom mounted
bfg9000
bfg9000's Gravatar
11/15/16 6:39 PM
Works fine on my bike. That's the procedure in the user manual.
Maybe your SEL button contacts are dirty?
Nastynotch
11/15/16 7:55 PM
I thought about that too, but it works when toggling through power and TC modes.
2013 ZX-14R SE
V1 custom mounted
Nastynotch
11/16/16 4:01 PM
Here's a short vid I made showing what I'm trying, as well as showing the button does in fact work to toggle through TC, and power modes.
* Last updated by: Nastynotch on 11/16/2016 @ 4:09 PM *
2013 ZX-14R SE
V1 custom mounted
Nastynotch
11/20/16 7:43 AM
Okay kind of an update, I tried the procedure on my neighbors 14R and it works no problem. Will not work on my bike, but the button itself does work. Only difference between his bike and mine is that mine has a flashed ecu and his is stock.
2013 ZX-14R SE
V1 custom mounted
11/20/16 7:54 AM
I think you pinpointed it. Disconnect the battery - cable and hook it back up at exactly midnight.
Nastynotch
11/20/16 10:46 AM
That looks like the only way I'll be able to solve this problem.
2013 ZX-14R SE
V1 custom mounted
joegdi
11/20/16 11:41 AM
So, question time. Why in the world would a Woolich (the Cblast flash is Woolich based, right?) based flash disable the ability to set the bike's clock? Has anyone else who has a flashed ECU also had their clock setting ability disabled? The implications of ECU flashing just took on new meaning. :-) As for me, I like to be able to set my clock. It does come in handy.
11/20/16 1:47 PM
I have had the Cblast flash for 2 yrs no issue changing the clock
11/20/16 4:27 PM
Can access setup fine with CBlast ECU.
Nastynotch
11/20/16 7:11 PM
Interesting indeed. I may pull negative battery cable tomorrow just to see if it will reset itself and start fresh. Beyond that all I can do is hook the battery up at noon or midnight.
* Last updated by: Nastynotch on 11/20/2016 @ 7:11 PM *
2013 ZX-14R SE
V1 custom mounted
Nastynotch
11/27/16 11:07 AM
Just a follow up. Disconnecting the negative battery cable for 24 hrs did nothing. It still retained clock memory. I guess I'm just out of luck here.
2013 ZX-14R SE
V1 custom mounted
11/27/16 8:00 PM
ahhhhhh--shit! It doesn't go back to 12. Well, you could look at the time it says and disconnect then hook back up when it really is that time. Man-oh-man, time travel is easier than that. Hope that works--but I'm guessing not or you would have tried??? Why that no work?
Nastynotch
11/28/16 5:13 AM
It doesn't display the time displayed before killing the power. It maintains the current time no matter what. This tells me it has some type of internal battery back up in the gauge cluster. Question is,how long does it take to loose its memory with no main battery connected. The much bigger question is why doesn't it Allow me to set it the way it was designed to be set.
2013 ZX-14R SE
V1 custom mounted
11/28/16 7:52 AM
This is a small trick you can try but maybe? When the chassis ground is connected to the neg terminal of the battery there is a complete circuit. When you disconnect the battery ground the negative or ground of the bike is floating. There is no place for any stored charge to dissipate. An old trick on cars was to completely disconnect the battery, then clamp the neg battery connection and clamp it to chassis and then connect the chassis to a good earth ground. Such as a wall plug ground or a gas or water pipe going into the earth. Some circuits take a bit of time to discharge, if you try this leave it connected for 10 min.
But, the symptoms sound like you have a component in the gage cluster gone bad to me. Recently had the gage cluster on a car go crazy and it stopped the car from running. Had to replace it with a used one to get rid of the faults.
Nastynotch
11/28/16 5:40 PM
There's a similar way I used to do that to cars and all I did was remove both terminals from the battery and touch them together. I guess I need to try that before throwing in the towel.
2013 ZX-14R SE
V1 custom mounted
TigerFire13
11/29/16 8:53 AM
I have the same issue as Nastynotch here. Cblasted last winter. Trying to access the config menu doesn't work, but TC and Power can be changed. Wasn't sure what caused it, but this seems like a real possibility now...
2013 Pearl Stardust White ZX-14R
Two Brothers 4-2-1 Carbon Fiber w/ Ceramic coated headers, Sargent Seat, Rostra Cruise Control, Oxford Heated Grips, Murph's Pegs, Denali Soundbomb, SW-Motech PLX Contour racks and Alu-Rack, Givi V35's and V56 w/ Kawi OEM trim, Fenda Extenda and Puig Hugger.
Nastynotch
11/29/16 10:31 AM
I may swap in my buddies stock ecu just out of curiosity.
2013 ZX-14R SE
V1 custom mounted
mad5674
mad5674's Gravatar
11/29/16 5:49 PM
I put 4000 mi. on my new '15 since Sept. 10, cold ride Sun. before putting her to bed for the winter...rode Sun. with ktrc off, and with the 40's air!!! Wow!! No flash for me because of tales like this, and so impressed with this bike compared to my old '11 that got rear ended! Good luck and hope you get it lined out, or at least find out for certain if the flash caused it or something else.
Mark D.
'08 1600 Vulcan
Nastynotch
12/04/16 4:08 PM
Update: Installed my neighbors stock ECU and I was able to access the settings page with no problem. So with my Cblasted ECU I can't access my settings page at all. There you have it folks, mystery solved.
2013 ZX-14R SE
V1 custom mounted
joegdi
12/04/16 9:16 PM
My, my. As the lawyer types would say, that is dispositive. Nastynotch, do you think it would be possible/worthwhile for Cblast to return your ECU to its initial factory state and then you give your reflashed-reflashed ECU another shot at setting the clock? If clock setting control returns with the ECU flashed back to stock, that would suggest (to me at least) that it was something in the flashing process that flipped the wrong bit(s). Given that, and with a little (lot?) of sleuthing on Cblast's part, perhaps the errant bit flip(s) could be found and subsequently eliminated.
I've toyed with having my ECU flashed. But between the Vic Thing test results of a Cblasted ECU (no measurable performance improvement) and now this anomaly I remain a little gun shy concerning the relative merits of the whole ECU reflashing process. Then again, maybe I'm just a worry wart. :-)
12/04/16 9:46 PM
I would try and reach out to Nells who actually does the tuning and dyno work - I believe the ex-cblast was just the middle man in the zx14 community? His number is around here somewhere
Nastynotch
12/05/16 3:59 AM
I don't know what I'm going to do at this point. I've sent in my ecu at least 3 times for revisions, and I'm almost certain that it has worked before with the Cblast ecu. Trying to decide if it's worth the hassle to fix this, or just swap in my buddies ecu twice a year.
2013 ZX-14R SE
V1 custom mounted
